× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
ReadyNAS Duo Copying is slow and gives error 0x8007003B
dashffkjdgfaso
I can't copy anything or use my ReadyNAS duo while connected to our router - it is incredibly slow (10's of KB) at the best of times and simply errors out most of the time.
If I disconnect the router it works perfectly - but no intrenet...
I've checked the MTU size, and piniging packets etc. and that seems fine, Jumbo frames are disabled on my computer.
How do I go about troubleshooting the router/switches?
Current configuration is Edge router->TP-Link switch->netgear switch which goes to both my computer and the ReadyNAS (it was originally setup without the netgear switch with the same problem).
Message 1 of 3
Accepted Solutions
dashffkjdgfaso
Re: ReadyNAS Duo Copying is slow and gives error 0x8007003B
Thanks for your help, I've fixed the problem though.
It was a network driver issue on my computer and the NAS started working after uninstalling and reinstalling.
Message 3 of 3
All Replies
mdgm-ntgr
NETGEAR Employee Retired
Did you have any ports forwarded to your NAS?
Do you have a backup of your data on the NAS?
Can you send me your logs (see the Sending Logs link in my sig)?
Message 2 of 3
dashffkjdgfaso
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 3508 views
  • 0 kudos
  • 2 in conversation
Announcements
