× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
ReadyNAS Duo - private keys
Fatman1
Hi,
I want to store a private SSH key on my NAS. I can't seem to make the file permissions restrictive enough though.
In Linux, I try:
$ sudo chown fatman ./nikko2.ppk
$ ls -la
total 1024
drwxr-xr-x 1 root root 0 2011-09-19 15:08 .
drwxr-xr-x 1 root root 0 2011-09-23 11:48 ..
-rwxr-xr-x 1 root root 821 2011-01-18 09:20 nikko2.ppk
Didn't error, but clearly didn't work either.
In Windows, I try to set the owner to user fatman. That doesn't error either, but it still doesn't take.
How do I set the owner on this file?
Thanks.
Message 1 of 7
sphardy1
Apprentice
Re: ReadyNAS Duo - private keys
How are you connected to the ReadyNAS? (ie what protocol) And why do you have files & folders owned by root? How were they created? What linux distribution are you using?
Message 2 of 7
Fatman1
Thanks for the reply. To answer your questions:
1. CIFS in both cases.
2/3. Files and folders owned by root seems to be the default. I created the file by copying it from one of my NTFS disks in Windows.
4. Linux distro: Ubuntu Server 10.04 LTS.
[edit]
Oh, I didn't make it clear, but when I entered the commands in my previous post, the current directory was the mount point for the NAS share.
Message 3 of 7
sphardy1
Apprentice
So the NTFS disk explains the root ownership issue (that's a generic issue of using NTFS drives with Linux, there are other ways to mount and avoid this)
But as the files are owned by root and you are accessing the NAS via CIFS, unless you connect to the NAS as the admin user you will not have rights to the files (only admin user has root privileges over CIFS) so chown would be expected to fail
Silent failure of the chown command is a minor worry, but have to admit I don't use CIFS under linux so haven't tried to change ownership/permissions this way
Message 4 of 7
Fatman1
From Linux I'm connecting to the NAS as LINUXBOX\root. That suits me as I'm mounting the NAS in a root-owned location in the file tree.
After that I'm using "sudo" to mimic root, so chown should not fail.
And chown should never fail silently. It's almost as if the NAS filesystem is returning success to the chown command, but failing internally.
Message 5 of 7
sphardy1
Apprentice
I'm surprised you can connect as root, and the symptoms suggest you aren't actually connected as root.
If you have SSH root access enabled you could check via the smbstatus command
Message 6 of 7
Fatman1
Now I'm trying to connect as the matched UID user (see other thread) with the command:
sudo mount.cifs //nas/media /nas/media -ouser
which passes the shell's credentials on to smbclient (I think). I enter the password when prompted and smbclient connects the share.
This smbstatus output confuses me. Doesn't seem to make a lot of sense.
nas:/media/keys# smbstatus
Samba version 3.0.37
PID Username Group Machine
Service pid machine Connected at
media 8212 10.xx.xx.xx Sun Sep 25 02:36:20 2011
No locked files
No user. What the heck?
The two systems (LINUXBOX and NAS) show the same file with different permissions.
On the NAS:
nas:/media/keys# ls -la
total 48
drwxrwxrwt 2 nobody nogroup 16384 Sep 19 15:08 .
drwxrwxrwt 13 nobody nogroup 16384 Sep 23 11:48 ..
-r-------- 1 fatman users 821 Jan 18 2011 nikko2.ppk
which is correct. From LINUXBOX:
fatman@nikko:/$ ls -la /nas/media/keys/nikko2.ppk
-r-xr-xr-x 1 root root 821 2011-01-18 09:20 /nas/media/keys/nikko2.ppk
which is completely wrong. I guess some UID translation is going on?
Oh, I'm confused. Maybe some sleep will un-confuse me.
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 774 views
  • 0 kudos
  • 2 in conversation
Announcements
