× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
ReadyNAS Ultra 2 - Disable RAID?
LaRock1
I would like to add 2 drives to the ReadyNAS Ultra 2, but would like to have them operate as 2 independent drives, Not RAIDed. I looked thru the user's manual, and I didn't see an option to disable raid. Maybe I'm missing something. Do anybody know if this is possible?
Thanks in advance for your time.
Message 1 of 4
Guru
Re: ReadyNAS Ultra 2 - Disable RAID?
The ultra 2 only supports two drives, so you are starting diskless?
Anyway, you can set up two Raid-0 volumes (one on each drive). Raid is technically not disabled, but this has the same effect - both drives are independent, and have no redundancy. If your unit is already set up, you would need to do a factory reset to get into this mode (which would wipe all the data on the ultra).
Message 2 of 4
ReadySECURE
Apprentice
StephenB is right on this one. The device is designed to be a RAID device. Disabling RAID is not an option, and it's also not recommended. If you want to explore Flex-RAID options, you will have to factory default and reconfigure the RAID settings accordingly.
Message 3 of 4
TeknoJnky
Hero
Also, if you intend to use flexraid for 'separate drives', this still won't work if want to try to add/remove the drives 'for backup'. The device is designed to keep drives in it until they either fail or are upgraded. Once you pull a drive, its marked as failed and you will not be able to re-add it without it getting formatted.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1112 views
  • 0 kudos
  • 4 in conversation
Announcements
