× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
ReadyNAS Ultra 2 after power outage, no longer starting cifs/ samba
arlensen
Last week tuesday, I have had an power outage.
And so the ReadyNas Ultra 2 was restarted. It was running fine afterwards.
However in the evening, I tried to watch a movie, which resides on the NAS, and I was unable.
So then the investigation started, and I was unable to access my shares, and checking from the gui, cifs/ samba is not started.
and if I enable it, and press apply, it says, OK, will do, but nothing happens.
If I go to logs, I have no entries.
What I tried as fix, was to re-install the base OS, the non disruptive option, and this did NOT solve the problem.
What I can do, but only if you say it makes sense, is reset to factory default, and wipe the data, as I have a backup. But I see that as a last resort.
Do you guys/ ladies, maybe have any ideas ?
Message 1 of 6
arlensen
Re: ReadyNAS Ultra 2 after power outage, no longer starting cifs/ samba
some more info:
Model:ReadyNAS Ultra 2 [X-RAID2]
Serieel:***
Firmware:RAIDiator 4.2.27
Geheugen:1024 MB [DDR3]
IPv4-adres: 1:Niet verbonden
IPv4-adres: 2:192.168.178.21
Volume C:Online, X-RAID2, 2 schijven, 89% van 1846 GB gebruikt
language is dutch, but I think it is understandable
Message 2 of 6
Guru
Are you running CrashPlan?
Message 3 of 6
arlensen
Yes I am. But yesterday started with reset to factory defaults. And so far looking good. Cifs is working again. Was rebuilding x raid 2. Taking time. Will update further later this week
Message 4 of 6
arlensen
after digging further, I can understand the crashplan question.
most likely not the correct java version 7 or 8 was there, and was crashplan each time trying to update, this failed, but this might also have caused the filesystem to become full
to bad I am now in the process of factory reset, possibly I would have been able to fix it by means of ssh access, to create space
Message 5 of 6
arlensen
hi all,
after some jre version 8 troubles, and sligth change in how to connect.
i have now crashplan running again, on the netgear!!!
now synchronising block info, and afterwards, I will start the restore, and then the waiting will start, to have all the 1,6Tb restored.....
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 2152 views
  • 0 kudos
  • 2 in conversation
Announcements
