- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ReadyNAS is showing up as having two ip addresses on my home network
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
I was wondering if someone could help me. I have a ReadyNAS that is working correctly on my home network. It has an IP address of 192.168.1.2, all my other devices on the network start 192.168.1.XX.
There is however an unknown device that is showing up on my BT home hub, which has an IP address of 172.31.51.213. When I use Fing to scan services on this ip address it finds 554 and 7070.
If I unplug my ReadyNAS from the home network then both the 192.168.1.2 and the 172.31.51.213 addresses are no longer seen on the network, so Im pretty sure that they are noth the ReadyNAS.
I am wondering what the second IP address is for, whats going on. I do use my readyNAS to host a VPN if that makes any difference.
Thanks in advance
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
The 172.31.51.213 address won't work on your 192.168.x.x network, and (like 192.68.1.2) is a private (not internet routable) address.
Port 554 (and sometimes 7070) are used for media streaming, but there also are a lot of reports of false alarms reported by various port scanners for those two ports.
What ReadyNAS model and firmware?
If you have two ethernet ports are both connected?
Did you try disabling the openvpn service and rebooting the NAS?
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ReadyNAS is showing up as having two ip addresses on my home network
Hi mark3,
Welcome to the community!
I don't remember the OpenVPN add-on or server use these ports that you mentioned. Are you using the ReadyNAS as a media server for your Apple devices or through iTunes?
Kind regards,
BrianL
NETGEAR Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Brain and Stephen,
Thanks very much for your advice. I had previously disabled the VPN but it was still appearing, however I did not think to restart the readyNas.
Alas, after disabling the VPN Server I restarted and it has now disappeared. Thanks for your help.
Mark
