- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ReadyNAS6 Pro failed to boot with "could not properly extract" after Upgrade from 6.6.1 to 6.7.3
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
urgent call:
- Just updated from 6.6.1 to 6.7.3, during this upgrade a boot message came up with "ERR: could not properly extract".
I cannot reach the system by SSH to look what happened, and I eventually will loose data as i don't know if the last backup (yesterday) is intact.
Thank you for you help.
regards
GOI
Addendum:
- Booting with no disks -> could be found in Raidar -> so at least not bricked.
- now checking boot with disks if it can be found in Raidar
-> booting with disks does NOT work: Could not be found in Raidar.
- now checking with dedicated network (PC <-> ReadyNAS6)
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Solved by mdgm:
- copied the root (md0) partition
- a rebuild of the md0 partition was made
- recopied the data back to md0
- and initiated an os extract on next reboot again
not to forget:
MANY THANKS TO MDGM! You saved my day.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Betreff: ReadyNAS6 Pro failed to boot with "could not properly extract" after Upgrade from
Addendum:
- Booting in Service Mode (aka Maintenance Mode aka Tech Support Mode):
-> works and gives me a telnet access -> but whats the user name and the password?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Betreff: ReadyNAS6 Pro failed to boot with "could not properly extract" after Upgrade from
It's one thing to know how the credentials (which are not hard to find on the web), it's quite another to know what to do after you login. I've sent you a PM.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Solved by mdgm:
not to forget:
