- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Readynas 104 to 314 #26833764
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hiya
I have a readynas 104 with 6tb drives in it , I want to upgrade to a readynas 314 to be able to use max storage space
Can I just drop my drives from the 104 to the 314 and not loose my data?
Thanks
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Looking at your case it sounds like support has already fixed it and that remnants of having PHP installed at some point was the problem.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Readynas 104 to 314
First uninstall any apps you have installed.
Also, put a scratch disk (must not be from your array) in the RN314 and update the firmware on that to at least as new as what you were running on the RN104, verify the firmware update was successful, then power down, remove the scratch disk and migrate your disks across (keep the order the same).
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm assuming I just slide all 4 drives in and power up and let it do its thing ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
I guess this is the same process if i wnat to switch from 104 to 214?
greetings
alexander
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes
- Mark as New
- Bookmark
- Subscribe
- Permalink
agh!!
so i got my new readynas 314 .... did the scratch disk thing and updated my firmware ... powered down and migrated my disks over
now i cannot access the admin panel!!! i can see the data on the network , RAIDar sees the nas and allows me to reboot , get logs etc but when i click admin , it says ' connecting to admin ' and says ' readynas admin page offline '
any suggestions ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I suggest contacting Netgear support (support.netgear.com) so they can take a look.
What firmware are you running? Did you uninstall apps (per mdgm's procedure) before migrating the disks?
- Mark as New
- Bookmark
- Subscribe
- Permalink
6.4.2 is the firmware , which matched the old readynas 104's and i had no apps installed on the old nas 😞
- Mark as New
- Bookmark
- Subscribe
- Permalink
The admin ui runs at a low priority, so it is possible that some other activity (a volume check perhaps) is causing your problem. In that case, the admin ui should show up after some time,
Start with phone or chat support - that's the most direct path. If you don't have a current backup, you might start copying files to another device (just in case).
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Readynas 104 to 314 #26833764
im in chat with support atm 🙂 ill advise on any progress for those at home 🙂
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
yes it has been fixed !
now i have to work out how to get my full 24tb of space back as its reporting i have only 12tb of 16tb left when i actually have 4 x 6tb = 24tb
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you are using xraid or raid-5 then 4x6TB will give you 18 TB of storage. The remaining 6 TB is used for redundancy (protection against a single disk failure).
The NAS reports storage as TiB (1024*1024*1024*1024), not TB (1000*1000*1000*1000) - even though it calls it TB on the UI. 18 TB is the same as 16.4 TB - that's why your NAS is reporting 16. So this is completely normal (and it should have been reporting 16 TB before).
If you don't want RAID, you can switch over to JBOD- which will give you 4 volumes of 6 TB each.
RAID-0 is also possible (and would give you a single volume of 24 TB). But I don't recommend RAID-0. It is fragile - if any single disk fails you lose all 24 TB of data.
Either way, if you change the RAID mode you will need to destroy the current volume, create new ones using the mode you want, and reload all your data again. You'll also have to uninstall your apps first (and reinstall them after you've switched).
- Mark as New
- Bookmark
- Subscribe
- Permalink
thanks 🙂
im all happy now , i got an extra 4 tb by switching over to the readynas 314 and some extra goodies in the admin for monitoring
support were really great with getting my nas working ... having 4 netgear products , im sticking by em 🙂
thanks everyone for your help
