- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
SMB quits working
- Mark as New
- Bookmark
- Subscribe
- Permalink
SMB quits working
Hi!
Since yesterday I have increasing problems with my ReadyNAS 516. It runs 6 3TB harddisks, in X-RAID 6. It operates under OS 6.6.1.
It has worked for quite a while since the update to 6.6.1 very reliable. But suddenly, I have problems with the SMB service, which suddenly seems to quit and cannot be reactivated via the GUI (if I try to deactivate and reactivate I just get an error message that the status of the service could not be changed).
Once I could no longer use the NAS with SMB and rebooted the NAS I usually got stuck diring reboot with 18% or 22% forcing me to shut down the NAS hard. When rebooting, it then seems to restart again.
Research in the log files (via ZIP download) indicates that the root file system might be full, while standard data volumes are having more than enough free space:
From btrfs.log:
Label: '7c6e460a:Main' uuid: 056dd4f9-8a7c-4dda-b584-02e6792b9c0a
Total devices 1 FS bytes used 6.34TiB
devid 1 size 10.90TiB used 6.38TiB path /dev/md127
=== filesystem /Main ===
Data, single: total=6.36TiB, used=6.33TiB
System, DUP: total=32.00MiB, used=736.00KiB
Metadata, DUP: total=9.50GiB, used=8.42GiB
GlobalReserve, single: total=512.00MiB, used=1.69MiB
From volume.log:
=== df -h ===
Filesystem Size Used Avail Use% Mounted on
udev 10M 4.0K 10M 1% /dev
/dev/md0 4.0G 2.2G 1.4G 62% /
tmpfs 1.9G 0 1.9G 0% /dev/shm
tmpfs 1.9G 16M 1.9G 1% /run
tmpfs 960M 1008K 959M 1% /run/lock
tmpfs 1.9G 0 1.9G 0% /sys/fs/cgroup
/dev/md127 11T 6.4T 4.6T 59% /Main
/dev/md127 11T 6.4T 4.6T 59% /home
/dev/md127 11T 6.4T 4.6T 59% /apps
=== df -i ===
Filesystem Inodes IUsed IFree IUse% Mounted on
udev 490683 535 490148 1% /dev
/dev/md0 0 0 0 - /
tmpfs 491301 1 491300 1% /dev/shm
tmpfs 491301 766 490535 1% /run
tmpfs 491301 23 491278 1% /run/lock
tmpfs 491301 9 491292 1% /sys/fs/cgroup
/dev/md127 0 0 0 - /Main
/dev/md127 0 0 0 - /home
/dev/md127 0 0 0 - /apps
From smbd.log:
[2017/02/12 20:58:38.872148, 0] ../source3/lib/util.c:902(log_stack_trace)
#1 /usr/lib/x86_64-linux-gnu/libsmbconf.so.0(smb_panic_s3+0x20) [0x7f838db74a70]
#3 /usr/sbin/smbd(+0xb7c2) [0x5591a14527c2]
BACKTRACE: 12 stack frames:
#2 /usr/lib/x86_64-linux-gnu/libsamba-util.so.0(smb_panic+0x1c) [0x7f83900172dc]
#4 /usr/lib/x86_64-linux-gnu/libtevent.so.0(+0x9b13) [0x7f838c5a4b13]
#0 /usr/lib/x86_64-linux-gnu/libsmbconf.so.0(log_stack_trace+0x1a) [0x7f838db745da]
#6 /usr/lib/x86_64-linux-gnu/libtevent.so.0(_tevent_loop_once+0x8d) [0x7f838c59f24d]
#7 /usr/lib/x86_64-linux-gnu/libtevent.so.0(tevent_common_loop_wait+0x1b) [0x7f838c59f3eb]
#8 /usr/lib/x86_64-linux-gnu/libtevent.so.0(+0x7ff7) [0x7f838c5a2ff7]
#10 /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf5) [0x7f839028bb45]
#11 /usr/sbin/smbd(+0x7d7e) [0x5591a144ed7e]
#9 /usr/sbin/smbd(main+0x17da) [0x5591a144ebfa]
#5 /usr/lib/x86_64-linux-gnu/libtevent.so.0(+0x8057) [0x7f838c5a3057]
[2017/02/12 20:58:40.526904, 0] ../source3/lib/dumpcore.c:303(dump_core)
dumping core in /var/cores
[2017/02/12 20:58:41.108191, 0] ../source3/lib/dumpcore.c:303(dump_core)
[2017/02/12 21:03:54.018315, 0] ../source3/lib/util.c:478(reinit_after_fork)
[2017/02/12 21:03:54.073892, 0] ../source3/lib/util.c:478(reinit_after_fork)
[2017/02/12 21:03:54.163829, 0] ../source3/lib/util.c:478(reinit_after_fork)
messaging_reinit() failed: NT_STATUS_DISK_FULL
[2017/02/12 21:03:54.252399, 0] ../source3/smbd/server.c:758(smbd_accept_connection)
[2017/02/12 21:03:54.385396, 0] ../source3/smbd/server.c:758(smbd_accept_connection)
reinit_after_fork() failed
[2017/02/12 21:03:54.499331, 0] ../source3/smbd/server.c:758(smbd_accept_connection)
[2017/02/12 21:03:54.499364, 0] ../source3/lib/util.c:791(smb_panic_s3)
PANIC (pid 15325): reinit_after_fork() failed
[2017/02/12 21:03:54.885632, 0] ../source3/lib/util.c:791(smb_panic_s3)
[2017/02/12 21:03:54.760125, 0] ../source3/lib/util.c:902(log_stack_trace)
PANIC (pid 15324): reinit_after_fork() failed
PANIC (pid 15323): reinit_after_fork() failed
[2017/02/12 21:03:55.049690, 0] ../source3/lib/util.c:902(log_stack_trace)
[2017/02/12 21:03:55.138056, 0] ../source3/lib/util.c:902(log_stack_trace)
[2017/02/12 21:03:56.859592, 0] ../source3/lib/dumpcore.c:303(dump_core)
[2017/02/12 21:03:57.263164, 0] ../source3/lib/dumpcore.c:303(dump_core)
[2017/02/12 21:03:57.206050, 0] ../source3/lib/dumpcore.c:303(dump_core)
[2017/02/12 21:08:08.620599, 0] ../source3/lib/util.c:478(reinit_after_fork)
[2017/02/12 21:08:08.676184, 0] ../source3/lib/util.c:478(reinit_after_fork)
[2017/02/12 21:08:08.785429, 0] ../source3/smbd/server.c:758(smbd_accept_connection)
[2017/02/12 21:08:08.785388, 0] ../source3/lib/util.c:478(reinit_after_fork)
[2017/02/12 21:08:09.073466, 0] ../source3/lib/util.c:791(smb_panic_s3)
[2017/02/12 21:08:09.073482, 0] ../source3/smbd/server.c:758(smbd_accept_connection)
PANIC (pid 15392): reinit_after_fork() failed
[2017/02/12 21:08:09.165160, 0] ../source3/smbd/server.c:758(smbd_accept_connection)
[2017/02/12 21:08:09.487176, 0] ../source3/lib/util.c:791(smb_panic_s3)
[2017/02/12 21:08:09.369346, 0] ../source3/lib/util.c:902(log_stack_trace)
PANIC (pid 15394): reinit_after_fork() failed
[2017/02/12 21:08:09.645442, 0] ../source3/lib/util.c:791(smb_panic_s3)
PANIC (pid 15393): reinit_after_fork() failed
[2017/02/12 21:08:09.767188, 0] ../source3/lib/util.c:902(log_stack_trace)
[2017/02/12 21:08:11.631549, 0] ../source3/lib/dumpcore.c:303(dump_core)
[2017/02/12 21:08:12.250895, 0] ../source3/lib/dumpcore.c:303(dump_core)
[2017/02/12 21:08:19.031334, 0] ../source3/lib/util.c:478(reinit_after_fork)
[2017/02/12 21:10:16.686429, 0] ../source3/lib/util.c:478(reinit_after_fork)
[2017/02/12 21:10:16.760177, 0] ../source3/lib/util.c:478(reinit_after_fork)
[2017/02/12 21:10:16.827875, 0] ../source3/lib/util.c:478(reinit_after_fork)
[2017/02/12 21:10:16.827917, 0] ../source3/smbd/server.c:758(smbd_accept_connection)
[2017/02/12 21:10:17.026902, 0] ../source3/smbd/server.c:758(smbd_accept_connection)
[2017/02/12 21:10:17.026893, 0] ../source3/smbd/server.c:758(smbd_accept_connection)
[2017/02/12 21:10:17.083316, 0] ../source3/lib/util.c:791(smb_panic_s3)
[2017/02/12 21:10:17.249940, 0] ../source3/lib/util.c:791(smb_panic_s3)
PANIC (pid 16239): reinit_after_fork() failed
PANIC (pid 16241): reinit_after_fork() failed
PANIC (pid 16240): reinit_after_fork() failed
[2017/02/12 21:10:17.380678, 0] ../source3/lib/util.c:902(log_stack_trace)
[2017/02/12 21:10:17.443715, 0] ../source3/lib/util.c:902(log_stack_trace)
[2017/02/12 21:10:17.551820, 0] ../source3/lib/util.c:902(log_stack_trace)
And very strange from system.log:
Feb 12 14:22:29 RasslerNAS mysqld[10070]:
Feb 12 14:22:29 RasslerNAS mysqld[10070]: 170212 14:22:29 [Note] /usr/sbin/mysqld: Shutdown complete
-- Reboot --
Feb 12 21:19:12 RasslerNAS disk_event_handler[3181]: disk event handler called for add
Feb 12 21:19:12 RasslerNAS disk_event_handler[3182]: disk event handler called for add
Feb 12 21:19:12 RasslerNAS disk_event_handler[3184]: disk event handler called for add
Feb 12 21:19:12 RasslerNAS disk_event_handler[3185]: disk event handler called for add
The NAS was running the whole day. First reboot was this afternoon. But is seems that between the reboot this afternoon and the reboot this evening, logging into system.log was not working...
I have read, that the VirusScanner could be a reason for filling up the root file system. So I have not disabled the VirusScanner. I will investigate further.
Any idea, what could cause this problem.
Thanks and regards,
Michael
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: SMB quits working
Hello mhurler,
Can you try disabling AntiVirus from the admin page when you get chance and see if you get the same results?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello JennC,
thanks for your response.
I have now disabled AntiVirus on the NAS and will observe whether it runs stable again.
I will revert back in a couple of days.
Best regards,
Michael
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello mhurler,
You're most welcome. Just report back the results, we'll also see if others who get the same issue can share their resolution or ideas,
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi JennC,
After almost a week without AV the problem did not reoccur.
It would just be really good to use AV again. Any idea when the next stable release might be published?
Michael
- Mark as New
- Bookmark
- Subscribe
- Permalink
There is ReadyNASOS 6.7.0-T158 (Beta 1). There is no ETA as to when the production release will occur at this time.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I can confirm this issue is recurring. Logs show "System: Antivirus scanner found a threat (Heuristics.Broken.Executable) in the file /var/cores/core-smbd. Please delete the infected file soon if automatic delete setting is not enabled."
A reboot does help for a while. Disabling the AV seems to be the only stable solution.
-Scott
