- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
System volume 'root' usage is 100%
- Mark as New
- Bookmark
- Subscribe
- Permalink
System volume 'root' usage is 100 %. This condition should not occur in normal conditions. Please contact technical support.
I saw another post with the same error and it looks like they did some commands on the shell. I do not have ssh access (but can set it up if need be). Is there anyway I can troubleshoot prior to setting up ssh? They have no add-ons installed, very basic windows file server setup. They have a nightly backup that copies all data to an external drive, maybe it's a log file? On that note, is there a setting to keep logs 'trimmed'?
Thank you in advance!!!!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: System volume 'root' usage is 100%
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
root@nas-server:~# df -h
Filesystem Size Used Avail Use% Mounted on
rootfs 4.0G 3.9G 0 100% /
tmpfs 10M 4.0K 10M 1% /dev
/dev/md0 4.0G 3.9G 0 100% /
tmpfs 248M 0 248M 0% /dev/shm
tmpfs 248M 792K 247M 1% /run
tmpfs 248M 0 248M 0% /sys/fs/cgroup
tmpfs 248M 8.0K 248M 1% /media
/dev/md/data-0 462G 7.5G 436G 2% /data
/dev/md/data-0 462G 7.5G 436G 2% /apps
/dev/md/data-0 462G 7.5G 436G 2% /home
/dev/sdc1 597G 7.0G 590G 2% /media/USB_HDD_2
/dev/md/data-0 462G 7.5G 436G 2% /run/nfs4/home
/dev/sdc1 597G 7.0G 590G 2% /run/nfs4/media/USB_HDD_2
I do very little command line, how do I find out what files/folders are specifically too big?
- Mark as New
- Bookmark
- Subscribe
- Permalink
# du -csh /var
# du -csh /var/*
- Mark as New
- Bookmark
- Subscribe
- Permalink
root@nas-server:~# du -csh /var
3.6G /var
3.6G total
root@nas-server:~# du -csh /var/*
4.0K /var/agentx
46M /var/backups
34M /var/cache
4.0K /var/cores
4.0K /var/ftp
38M /var/lib
4.0K /var/local
0 /var/lock
3.5G /var/log
4.0K /var/mail
12K /var/netatalk
4.0K /var/opt
368K /var/readynasd
0 /var/run
16K /var/spool
4.0K /var/tmp
8.0K /var/www
3.6G total
So it appears that the log folder was totally full. So instead of being smart and deleting the logs from Frontview (or w/e the web interface is called in OS 6), I decided to try and be smart and delete all the logs from the shell...
root@nas-server:~# rm -rf /var/log/*
4.0K /var/agentx
46M /var/backups
11M /var/cache
4.0K /var/cores
4.0K /var/ftp
38M /var/lib
4.0K /var/local
0 /var/lock
12K /var/log
4.0K /var/mail
12K /var/netatalk
4.0K /var/opt
368K /var/readynasd
0 /var/run
16K /var/spool
4.0K /var/tmp
8.0K /var/www
93M total
It worked. But, it deleted all the subdirectories in the /var/log folder, which are required by ReadyNAS to write logs period. I went and tried turning on email alerts again and kept getting an error that the log/*whatever* directory didn't exist...
So, can anyone running 6.1.1 give me a list of all the subdirectories of /var/log in a clean install??? I really don't want to do a factory reset for such a minor error...
- Mark as New
- Bookmark
- Subscribe
- Permalink
root@nas-server:/var/log# mkdir frontview
root@nas-server:/var/log# cd frontview
root@nas-server:/var/log/frontview# touch msmtp.log
That allowed me to send alert messages now. But I'm worried that I've deleted more folders/files that are gonna cause issues down the road. If I have to do a factory reset, I can, I would just like to avoid it if I can find another solution.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try
# touch /.os_update
# rn_shutdown -r
The above will get the NAS to do an OS Re-install which will re-install the OS but leave your data intact.
I would have recommended finding the log file(s) that filled the OS partition and overwriting them e.g.
# echo "" > /var/log/mylog.log
Clarification: Please note that an OS Re-install should only be done after space on the OS partition has been freed up. Doing an OS Re-install whilst the OS partition is very full may lead to further issues.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Also, what can I do to prevent the log files from getting too big in the future?
- Mark as New
- Bookmark
- Subscribe
- Permalink
kokomodrums wrote: Thanks for the advice, I will try to OS reinstall next. Will I have to create new users after the reinstall or does it keep all settings intact as well?
It keeps all users. Only settings for which bad values could lock you of of a system would be reset. So the admin password and some network settings would be reset.
Well without knowing which log file filled up the OS partition it is difficult to say.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Maybe log in with ssh, and look around to see what is using the space.
lobbie1978 wrote: Just received the same error message 15 minutes ago and 5 minutes ago. I deleted the logs from Frontview, but the error message remains... 😞 I have SSH enabled.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I think I found the problem. For some reason the 'Transmission' add-on installed the download folder in the root directory, filling up the root dir rapidly. Although in the config.json file, the download directory is /Data/Transmission/Incomplete
Weird...
- Mark as New
- Bookmark
- Subscribe
- Permalink
So I'm running into this. Right now I am getting emails every 10 minutes saying root is at 100%.
However, df shows everything is fine. Rebooting didn't appear to help...
Is there some hidden space or something??
- Mark as New
- Bookmark
- Subscribe
- Permalink
Did you also check inodes? df -i
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yea, df -i looks fine:
root@Storage:/var# df -i Filesystem Inodes IUsed IFree IUse% Mounted on rootfs 0 0 0 - / tmpfs 504422 524 503898 1% /dev /dev/md0 0 0 0 - / tmpfs 504422 2 504420 1% /dev/shm tmpfs 504422 729 503693 1% /run tmpfs 504422 4 504418 1% /sys/fs/cgroup tmpfs 504422 2 504420 1% /media /dev/md126 0 0 0 - /data /dev/md126 0 0 0 - /home /dev/md126 0 0 0 - /apps tmpfs 504422 7 504415 1% /var/replicate/shm tmpfs 504422 1 504421 1% /home/Andra/snapshot tmpfs 504422 1 504421 1% /data/home/Andra/snapshot tmpfs 504422 1 504421 1% /home/Scott/snapshot tmpfs 504422 1 504421 1% /data/home/Scott/snapshot
So, I did have a couple of things in /var/lib which were taking up space (squeezeboxserver, and mysql). I was able to relocate those to /apps.
But now I am here (which is better):
root@Storage:/# df -h .
/dev/md0 4.0G 2.8G 898M 77% /
and I can't figure out what is taking the space...
root@Storage:/# du -sh /var 305M /var
Any other places I should look?
- Mark as New
- Bookmark
- Subscribe
- Permalink
This morning I am back to nearly 100% used:
root@Storage:/var# du -sh * 0 agentx 61M backups 100M cache 38M cores 0 ftp 46M lib 0 local 4.0K lock 66M log 0 mail 8.0K netatalk 0 opt 960K readynasd 0 replicate 4.0K run 4.0K spool 0 tmp 4.0K www root@Storage:/var# df -h . Filesystem Size Used Avail Use% Mounted on /dev/md0 4.0G 3.6G 123M 97% /
Where's the space going??? Help!
- Mark as New
- Bookmark
- Subscribe
- Permalink
OK, think I found it. Appears crashplan was doing something odd (upgrade folder was pretty big). Relocating it to /apps and will investigate further.
- Mark as New
- Bookmark
- Subscribe
- Permalink
You need to upgrade java to 1.7 or 1.8. I provided a link on your other post.
