Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Ultra 2 - Password
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-03-06
10:19 AM
2012-03-06
10:19 AM
Ultra 2 - Password
Hi
I have a Macbook Pro and got a Readynas Ultra 2.
I got it to work some time back but didn't use it for a while.
I upgraded til Lion and got problems with the Mac and had to do a fresh install of Lion.
Now i tried to get access to the NAS again and installed the software. I can see NAS and i try to click "setup"
I must have forgotten the password to Frontview, cause i can't get access.
I tried password recovery and it says that a new password will be sent to my mail, but it doesn't (or else it's more than 5 weeks on the way : )
I tried to reset the server. Press reset with a paperclip, press the button over the USB port two or four times so LED 1 or 2 is lit. (i've tried both). Then click reset again.
Default password: admin/netgear1 doesn't work.
Anyone has some good advice what i can try or what i have done wrong ?
Thx
Thx
Message 1 of 10
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-03-08
12:47 AM
2012-03-08
12:47 AM
Re: Ultra 2 - Password
Definitely you need perform OS reinstall to restore the admin password to default
here is a document to guide you how to do this(go to page 17):
http://www.readynas.com/download/docume ... ept-11.pdf
Message 2 of 10
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-03-08
01:59 AM
2012-03-08
01:59 AM
Instructions are also here: http://www.readynas.com/kb/faq/boot/how_do_i_use_the_boot_menu#ultra_2_ultra_2_plus_pro_2_duo_v2
Message 3 of 10
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-03-08
07:33 AM
2012-03-08
07:33 AM
Keep in mind that when you perform an OS Reinstall, it will reset not only the username and password for the admin UI. It will also reset the NICs back to their defaults. So if you have statically assigned IP addresses in the system, they will be removed from the NAS.
Message 4 of 10
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-03-08
08:03 AM
2012-03-08
08:03 AM
Thx for replies.
I've tried with both LED1 (Factory default) and LED2 (OS reinstall)
But i'll try again.
What exactly should i do ?
- Power off
- Paperclip on "reset" and power on.
- Led light up
- Push button 4 times so LED2 lid up
- Push reset again with paperclip (not hold, just push)
- ?? (power off ?) (leave it on for x min ?)
But i'll try again.
- Power off
- Led light up
Message 5 of 10
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-03-08
09:10 AM
2012-03-08
09:10 AM
As it is stated in the link, here is the layout to the related options in the boot menu.
1. Power off your unit.
2. Using a straightened paper clip, press and hold the Reset button.
3. Press the Power button to power on the unit.
4. Continue to press the Reset button until the Power button LED, USB and backup status LED, disk 1 LED, and disk 2 LED are lit
5. Press the Backup button to scroll through the boot mode options.
The unit shows the boot mode options using the LEDs, as described in the following table:
Boot Mode / Status Indicator
Normal / Power LED is lit.
Factory default / Disk 1 LED is lit. Warning: This erases ALL data on the drives!!!!!!!!
OS reinstall / Disk 2 LED is lit. This option resets your password and NIC settings
Press and release Reset button to confirm your boot menu selection.
After you confirm the selection, the NAS will shut down and reboot performing the selected task. I really hope that you did not factory default the device; because all your data will be gone, and you will have to set up the unit like it's brand new again.
Message 6 of 10
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-03-09
12:25 AM
2012-03-09
12:25 AM
I have tried both before, but since all data is still there and password has not been reset i guess it hasn't worked 🙂
I'll try again in the weekend with a OS re-install.
Thx again
Thx again
Message 7 of 10
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-03-09
09:44 AM
2012-03-09
09:44 AM
No problem. Let us know how things turn out, and please be sure not to chose the factory default option. 🙂
Message 8 of 10
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-03-09
12:00 PM
2012-03-09
12:00 PM
It worked 🙂
I think i have been to fast to turn of the NAS instead of letting it boot itself.
Thx again and have a nice weekend
Message 9 of 10
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-03-09
01:45 PM
2012-03-09
01:45 PM
You do the same Noogii, I'm glad it worked for you. 🙂
Message 10 of 10
