- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Ultra 6 Performance question
- Mark as New
- Bookmark
- Subscribe
- Permalink
I had this for about 4 years and was never happy with its speed. And I just want to confirm if the speed I'm getting is normal.
ReadyNAS Ultra 6 with three 3TB disks (2 seagate and 1 WD) in X-Raid 2. Jumbo frames are off (actually hurt transfer speeds in my case) and log is turned off. Write caching is on. Network ports are set to auto and reports that gigabit is enabled. All switches and routers are gigabit capable and enabled. All Cat6 cables.
When transferring a folder with a lot of files, both small and large, I'm getting around 20~30Mbps. When I transfer the same folder to our file server with RAID-10, I get about 100Mbps.
We originally purchased the NAS hoping that it would serve as our file server but the performance is so slow that we just use it as backup storage.
Is the speed I'm getting normal?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Ultra 6 Performance question
How are you transferring the files? (cifs?)
If you have a chance maybe run NasTester (http://www.808.dk/?code-csharp-nas-performance) and share the results here.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, cifs and dragging and dropping to mapped drive. From Win10.
Tried the program and getting this error when using drive letter.
An error occured: Could not find a part of the path 'N:\1test.tmp'.
When I use IP address or network name, I get this,
An error occured: The network name cannot be found.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Got the tester working. It gives those errors if I run it as administrator???
Running a 400MB file write on N: 5 times...
Iteration 1: 29.85 MB/sec
Iteration 2: 29.46 MB/sec
Iteration 3: 28.02 MB/sec
Iteration 4: 28.68 MB/sec
Iteration 5: 28.27 MB/sec
Average (W): 28.85 MB/sec
Running a 400MB file read on N: 5 times...
Iteration 1: 93.46 MB/sec
Iteration 2: 89.19 MB/sec
Iteration 3: 94.99 MB/sec
Iteration 4: 94.94 MB/sec
Iteration 5: 95.06 MB/sec
Average (R): 93.53 MB/sec
- Mark as New
- Bookmark
- Subscribe
- Permalink
Read speed is as expected.
The write speeds look about 1/2 what I'd expect to see with an ultra-6 running single redundancy xraid.
You do have the write cache enabled?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes. Mentioned it on the original post.
- Mark as New
- Bookmark
- Subscribe
- Permalink
You mentioned the brand of the disks, but not the model.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Seagate ST3000DM001 3TB
WD Red 3TB NAS Hard Drive WD30EFRX
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I just checked off write caching and it didn't make any difference in write speed. Perhaps the write caching isn't working?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Maybe try disabling the journalling also.
Have you looked at the SMART stats for the disks?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Journaling was always off. And the Smart all checks out. Do I have to reboot the NAS after changing write caching? It didn't auto restart.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm not sure, but it wouldn't hurt to reboot it.
If its been up a long time, its possible that a reboot might improve performance generally though.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Rebooting after changing the write caching doesn't make a difference. What would be the reason for write caching not having any effect?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Tripod3D schrieb:Rebooting after changing the write caching doesn't make a difference. What would be the reason for write caching not having any effect?
Do you find a solution to your performance problem? My Ultra 6 (Version 4.2.28, 4x WD30EFRX, X-Raid2, Smart OK, only write cache on) has similiar performance problems with cifs file transfer. (~30 MB/s write / ~60 MB/s read)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is journalling disabled?
Are these large file transfers?
- Mark as New
- Bookmark
- Subscribe
- Permalink
My Ultra 6 (Version 4.2.28, 4x WD30EFRX, X-Raid2, Smart OK, only write cache on) has similiar performance problems with cifs file transfer. (~30 MB/s write / ~60 MB/s read)Is journalling disabled?
File size ~ 4GB per file.
Journalling was disabled. I switched it on and off, restarted the NAS now it works normal with read ~100MB/s and write ~80MB/s!
Thank you for your response.
- Mark as New
- Bookmark
- Subscribe
- Permalink
That's great news (though I am thinking it might have been the restart that did the trick).
