- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Unable to view admin page, RAIDar 'Management service offline'
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm trying to access our companies ReadyNAS and it keeps showing up an error/warning screen when trying to view the web admin page. This is after it requests and accepts the login credentials.
On opening RAIDar as mentioned in what support documentation i can find that software is showing a message of 'Management service offline'.
I've downloaded logs using the RAIDar system but can't seem to see anywhere to upload them on this page.
I've rebooted the device several times through the RAIDar software, switching off the device and just removing the plug. None of which made any difference at all.
We don't go on the admin page very often only when doing the reporting and due to this I can't tell if or what it was doing at the time when the admin service went offline.
I need to regain access to the system without formatting the system as we have terabytes of artwork on it we have nowhere else to move to.
The drives and data are all working fine at present (touch wood) but we report on the state of the device for our ISO standards so the admin page is JUST as important to us.
Any advice would be helpful.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello Ziffel,
Firmware version 6.7.5 was recently release, you may want to try this version.
Marty
NETGEAR Community Team
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Unable to view admin page, RAIDar 'Management service offline'
What firmware is running on the NAS? Was it just updated?
As far as logs go, the process there is that you'd email them when requested by a Netgear mod. There is some information leakage when you post the the full log zip file publicly.
Note I don't work for Netgear. So wait a bit and see if @mdgm-ntgr or another Netgear mod asks. The email address you'd use is buried in this knowledge base article: https://kb.netgear.com/21543/How-do-I-send-all-logs-to-ReadyNAS-Community-moderators
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for all the handy information. I'll keep my eyes peeled for a mod post if i get one.
The machine is running firmware 6.7.3. I havent done a firmware upgrade in a while so if that has updated recently its been through auto update.
I'm not sure if i enabled ssh or how to connect and update firmware via ssh. I can't even find anything in the instruction manuals about how the process works.
- Mark as New
- Bookmark
- Subscribe
- Permalink
If it's enabled you can connect with putty on a Windows PC, or terminal on OSX. The username is "root", the password is the NAS admin password.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sure. Send the logs in if you want.
If you suspect you may have run into an issue fixed by 6.7.4 or 6.7.5 Beta 1 you can try updating using https://ip.address.of.nas/fwbroker
Note that it's important to check some things in the logs before jumping to that conclusion e.g. disk health, volume is mounted fine, fullness of root volume etc.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I've posted the logs to you now.
I'll wait for a response before updating or reinstalling the firmware from the web link you listed.
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
I would think from looking at your logs that updating the firmware is worth a try.
- Mark as New
- Bookmark
- Subscribe
- Permalink
No change, I now have 6.7.4 installed and runnind but the management service is still offline and the web page is unavailable.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Not sure if this helps anyone but the network activity light is constantly flashing.
Still having issues though
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm guessing as the standard 'off the shelf' fixes have not worked, no ones bothered about it now.
Ok I'll sort it myself.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello Ziffel,
Marty
