× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Volume: System volume 'root' usage is 88 %
tdcrosby
I have looked all over looking for the right solution for this issue. I entered the following command "du -hxm --max-depth=1 / | sort -h" and get this result
36      /lib
127    /opt
270    /var
405    /usr
2441  /root
3320  /
I have read to look for log files, or any file that seems to be large. But I am not finding any large files. When I ls the /root directory it shows only 2 /data and /Videos.
I am only running the Sabnzb+ and Sickbeard apps.
When I run "df -h" here is the results
Screenshot from 2015-09-04 15:42:07.png
Any ideas?
Thanks
Message 1 of 13
Guru
Re: Volume: System volume 'root' usage is 88 %
/dev/md0 should be ~25% full, not 88% full.
When I ls -al /root I see
root@RN102:/etc# ls -al /root
total 44
drwx------ 3 root root 4096 Jul 28 15:21 .
drwxr-xr-x 26 root root 4096 Aug 24 12:35 ..
-rw------- 1 root root 18297 Sep 3 19:55 .bash_history
-rw-r--r-- 1 root root 570 Jan 31 2010 .bashrc
-rw-r--r-- 1 root root 1694 Jul 12 2013 dashboard-status.log
-rw-r--r-- 1 root root 140 Nov 19 2007 .profile
drwx------ 2 root root 4096 May 9 2013 .ssh
No /video or /data stuff.  Can you post what you are seeing?  There really shouldn't be much in /root.  So there could be a clue here.
For logs, start by looking in /var/log and its subfolders.
Message 2 of 13
tdcrosby
Screenshot from 2015-09-04 16:45:03.png
Message 3 of 13
Guru
if you cd \root\data and do an ls -al what do you see?
Same question for \root\Videos
Not sure how they got there, but I think they shouldn't be.
Message 4 of 13
tdcrosby
When I cd /root and ls -al I get
Screenshot from 2015-09-04 18:28:20.png
I don't think they should be there either. Those directories were initiallly set up through the web interface. I didn't create them manually through CLI.
Not sure how to correct this one.
Message 5 of 13
Guru
Are these shares you created?  Or are these folders somehow related to the two add-ons?
Message 6 of 13
tdcrosby
I created the Videos share on the existing data share and then pointed the apps to them.
Message 7 of 13
mdgm-ntgr
NETGEAR Employee Retired
Well perhaps you got the path wrong.
Perhaps e.g. you needed to configure the path as e.g. /data but instead simply wrote data. Using the home folder for the root user as the working directory it then considered you wanted to use ~/data rather than /data
Message 8 of 13
Guru
Well you need to get rid of both of these folders, and I think that will resolve your space problem. (check of course!)
I don't use either app, so I'm not sure if you can simply reconfigure them or if you need to uninstall/reinstall them.
Message 9 of 13
tdcrosby
from cd /
Screenshot from 2015-09-04 18:51:37.png
from cd /data
Screenshot from 2015-09-04 18:52:52.png
from cd /data/Videos
Screenshot from 2015-09-04 18:53:50.png
As you can see ... browsing through the /data directory the screens are slightly different.
What would be your recommendation to fix this type of thing?
Message 10 of 13
Guru
Likely whatever is in /root/Videos needs to be copied to /data/Videos.   Then whatever app is writing to /root/Videos is reset to write to /data/Videos, and  then you delete /root/Videos deleted.
I'm not sure what to do about /root/data because I don't know what it is it.
Message 11 of 13
Guru
Another approach is to uninstall both apps, and delete both /root/data and /root/Videos.  Then reinstall the apps, and set up the target folders again.
BTW, I don't see anything wrong in your last two screen shots.
Message 12 of 13
tdcrosby
I found the issue.
The directories in the /root directory were not the right ones that is being used by the media server. I just removed both the data and the Videos directories from the /root directory ... end result
Screenshot from 2015-09-04 19:26:27.png
I wanted to make sure I was correctly setup with where my Videos go, so I created a file in the ~/data/Videos directory and it did not show up in the directory where my Plex server (separate workstation) is pulling the Videos. All is well. thanks for your help.
Message 13 of 13
Top Contributors
Discussion stats
  • 12 replies
  • 2744 views
  • 0 kudos
  • 3 in conversation
Announcements
