- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
dns not work after fatcory default
- Mark as New
- Bookmark
- Subscribe
- Permalink
After firmware update to 6.5.2, booting 99% and out of memory error occurred.
According to many advise here, I run backup & factory default.
After factory default, I set IP to fix 192.168.0.2 and add dns server 192.168.0.1 as usual.
I can access admin page at 192.168.0.2, but I can't send test mail from nas.
So i login into nas shell via ssh, it seems nas is refer to name server at 127.0.0.1.
But name server at 127.0.0.1 is not working.
Here is the output.
___________________________________________________________________________
admin@jwnas:~$ cat /etc/resolv.conf
# Generated by Connection Manager
nameserver 127.0.0.1
nameserver ::1
admin@jwnas:~$ nslookup google.com
Server: 127.0.0.1
Address 1: 127.0.0.1 localhost
nslookup: can't resolve 'google.com'
But there is a working local name server from netstat command.
admin@jwnas:~$ netstat -lnt
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address Foreign Address State
tcp 0 0 0.0.0.0:443 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:445 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:8200 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:5355 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:139 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:80 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:10000 0.0.0.0:* LISTEN
tcp 0 0 127.0.0.1:53 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:3702 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN
tcp6 0 0 ::1:4700 :::* LISTEN
tcp6 0 0 :::445 :::* LISTEN
tcp6 0 0 :::548 :::* LISTEN
tcp6 0 0 :::139 :::* LISTEN
tcp6 0 0 ::1:53 :::* LISTEN
tcp6 0 0 :::22 :::* LISTEN
Then add 192.168.0.1 to resolv.conf, dns is working.
nameserver 192.168.0.1
nameserver ::1
Server: 192.168.0.1
Address 1: 192.168.0.1 router.justware
Address 1: 216.58.200.206 nrt12s12-in-f14.1e100.net
Address 2: 2404:6800:4004:817::200e nrt12s12-in-x0e.1e100.net
I don't think I have to add 192.168.0.1 to resolv.conf manually.
I think there is still something wrong. I want to clear all potential risk before restoring data.
What should I do now? Any suggestion?
Thanks.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
127.0.0.1 is of course localhost.
Does it work if you add 8.8.8.8 as a DNS server?
BTW, a better strategy is to to leave the IP configuration as DHCP/Automatic in the NAS, and configure your router to reserve 192.168.0.2 for the NAS. Most routers provide a way to do this.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: dns not work after fatcory default
First, delete added line from resolv.conf.
Then add 8.8.8.8 via admin page, IT WORKED!
And after that even if I change dns server back to 192.168.0.1, it still work!
Not very clear about the reason, but problem is gone, Thanks!
