- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
snmp issue with 6.6.0
- Mark as New
- Bookmark
- Subscribe
- Permalink
Since upgrading to 6.6.0 I'm no longer able to monitor disk usage using snmp. I've been using cacti to graph my 312 for the last 2 years.
The system disk and the two disk in the NAS no longer appear when I query the device. With snmpwalk I still see swap, memory etc but not the physical disks.
HOST-RESOURCES-MIB::hrStorageDescr.1 = STRING: Physical memory
HOST-RESOURCES-MIB::hrStorageDescr.3 = STRING: Virtual memory
HOST-RESOURCES-MIB::hrStorageDescr.6 = STRING: Memory buffers
HOST-RESOURCES-MIB::hrStorageDescr.7 = STRING: Cached memory
HOST-RESOURCES-MIB::hrStorageDescr.8 = STRING: Shared memory
HOST-RESOURCES-MIB::hrStorageDescr.10 = STRING: Swap space
HOST-RESOURCES-MIB::hrStorageDescr.36 = STRING: /dev/shm
HOST-RESOURCES-MIB::hrStorageDescr.37 = STRING: /run
HOST-RESOURCES-MIB::hrStorageDescr.38 = STRING: /run/lock
HOST-RESOURCES-MIB::hrStorageDescr.39 = STRING: /sys/fs/cgroup
I've tried adding the disks to snmpd.conf and restart but I can't see them.
disk / 5%
includeAllDisks 5%
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re : snmp issue with 6.6.0
We have exactly the same problem. No more possible monitoring of the disk space since 6.6.0
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
The application we're using is "The Dude" from Mikrotik.
We were using in the past functions using "oids" to calculate for instance the total size available in Go for our ReadyNas 3130 : round((oid("1.3.6.1.2.1.25.2.3.1.5.36")*oid("1.3.6.1.2.1.25.2.3.1.4.36"))/(1024*1024*1024)).
Since release 6.6.0, it looks like no more oid correspond to the disk and we are no more able to use the functions to monitor the Size available, the used size, etc.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: snmp issue with 6.6.0
There is something strange going on here. I have given Netgear the benfit of doubt and loaded the MIB file that came with the 6.6.0 firmware update.
After executing snmpwalk -c **** -v2c -m "READYNASOS-MIB.txt" ip_address_of_netgear I still was only able to see the following paths
RFC1213-MIB::mib-2.25.2.3.1.3.33 = STRING: "/"
RFC1213-MIB::mib-2.25.2.3.1.3.36 = STRING: "/dev/shm"
RFC1213-MIB::mib-2.25.2.3.1.3.37 = STRING: "/run"
RFC1213-MIB::mib-2.25.2.3.1.3.38 = STRING: "/run/lock"
RFC1213-MIB::mib-2.25.2.3.1.3.39 = STRING: "/sys/fs/cgroup"
RFC1213-MIB::mib-2.25.2.3.1.3.56 = STRING: "/media/USB_HDD_5"
RFC1213-MIB::mib-2.25.2.3.1.3.57 = STRING: "/run/nfs4/media/USB_HDD_5"
This aligns with a standard SNMP Walk without the MIB File
HOST-RESOURCES-MIB::hrStorageDescr.33 = STRING: /
HOST-RESOURCES-MIB::hrStorageDescr.56 = STRING: /media/USB_HDD_5
HOST-RESOURCES-MIB::hrStorageDescr.57 = STRING: /run/nfs4/media/USB_HDD_5
I have attached 3 USB Storage Devices which I can see only 1 and I'm also missing the main Partion on the RAID
I'm not sure if this is deliberate to prevent NMS from accessing the appropriate data, but there has certainly been a change or introduced bug
- Mark as New
- Bookmark
- Subscribe
- Permalink
How to use SSH to monitor your Netgear NAS
For full disclosure, I'm a PreSales Engineer for Paessler AG in the APAC region. Paessler develops a Network Monitoring Solution called PRTG Network Monitor - https://www.paessler.com/
You can download the trial version, which converts to a 100 Sensor Freeware version after 30 days (100 sensors @ 10 devices).
I was able to see all me disks by using the SSH Disk Free Sensor - https://www.paessler.com/manuals/prtg/ssh_disk_free_sensor as illustrated below; (you will need to ensure that SSH is enables on the NAS)
Hopefully this will be a work around until the missing OIDs have been returned.
- Mark as New
- Bookmark
- Subscribe
- Permalink
+1 here.
my array is not visible in neither Observium, nor plain snmpwalk...
given the fact I upgraded to 6.6.0 solely to be able to configure SNMP location, I'm really impressed by the fact that I lost the most important functionality in return to this capability...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Done a bit more digging, Readynas 6.5.2 to 6.6.0 included an upgrade to Debian 8, Jessie. The snmpd version shipping with debian Jessie dropped support for btrfs file systems, this is a bug and has been fixed. There is a fix in later versions of snmpd 5.7.3+, currently installed 5.7.2.1+dfsg-1
http://lists.alioth.debian.org/pipermail/pkg-net-snmp-devel/2015-December/001680.html
https://sourceforge.net/p/net-snmp/bugs/2502/
It'll probably just work when they upgrade to Stretch, but that's probably going to be a while. Between now and then we'll have to hope that snmpd is upgraded in a Readynas update.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I've fixed this on my NAS, used some of my spare time over the holidays.
I built a Debian Jessie VM (amd64) and then followed the build instructions here to rebuild snmpd
apt-get build-dep snmpd
cd /usr/src
apt-get source libsnmp-base libsnmp5 snmpd
edits as below then
debian/rules binary
Used the source patch here to edit the source
edited the debian/rules to add --enable-ipv6 as it was building without IPv6 support for some reason.
Copied the .deb files to my nas and installed (dpkg -i ...) it's all working fine now and I don't seem to have broken anything.
libsnmp30_5.7.2.1+dfsg-1_amd64.deb
snmpd_5.7.2.1+dfsg-1_amd64.deb
snmpwalk results for before and after patch as closely as I'd expect and I can see the btrfs data now.
All my data is backed up elsewhere, I suggest you do the same before trying this.
- Mark as New
- Bookmark
- Subscribe
- Permalink
good job.
i was thinking about the same, but my RN10400 has an ARM CPU and i've got only a couple of Raspberry Pis. but it'd be easier than cross-compiling. maybe i'll give it a try on my only R-Pi 2 if i have some time in January...
ironically, i've bought this NAS in order NOT to have to customize ANYTHING and have simple wizards for EVERYTHING. the idea was that it'll all work out of the box.
i'd be able to solve this problem on my old MacMini 2006 (750 GB HDD + openSUSE 13.2 serving files using NFS & CIFS) or HP Microserver Gen8 (4x 4 TB in RAID 5 + CentOS 6 serving files using NFS & CIFS + virtualBox etc.) in a couple of minutes. maybe i should have bought another Microserver and load NAS4Free onto it 😞
- Mark as New
- Bookmark
- Subscribe
- Permalink
v.6.6.1 has been released yesterday. no SNMP thing is mentioned in its release notes...
- Mark as New
- Bookmark
- Subscribe
- Permalink
There are updated packages in our repository, so you can run `apt-get install libsnmp30` to fix this.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks. Working as expected with the updated versions.
- Mark as New
- Bookmark
- Subscribe
- Permalink
excuse me, Skywalker, but were you referring to x86/amd64 repositories?
because I'm afraid it's still not working on my ARM-based RN104.
actually there were no new packages, so I just forced reinstall of the original version and still no joy...
- Mark as New
- Bookmark
- Subscribe
- Permalink
The ARM packages are definitely there. Perhaps you are not running 6.6.1?
- Mark as New
- Bookmark
- Subscribe
- Permalink
hi Skywalker,
yes, you've nailed it!
I upgraded to 6.6.1 and run `apt-get install libsnmp-base libsnmp30 snmpd` and my monitoring is drawing all the lines again.
for the sake of completeness, there were some errors during the update, but they were harmless, I'd say:-
debconf: unable to initialize frontend: Dialog
debconf: (No usable dialog-like program is installed, so the dialog based frontend cannot be used. at /usr/share/perl5/Debconf/FrontEnd/Dialog.pm line 76.)
debconf: falling back to frontend: Readline
debconf: unable to initialize frontend: Readline
debconf: (Can't locate Term/ReadLine.pm in @INC (you may need to install the Term::ReadLine module) (@INC contains: /etc/perl /usr/local/lib/arm-linux-gnueabi/perl/5.20.2 /usr/local/share/perl/5.20.2 /usr/lib/arm-linux-gnueab
i/perl5/5.20 /usr/share/perl5 /usr/lib/arm-linux-gnueabi/perl/5.20 /usr/share/perl/5.20 /usr/local/lib/site_perl .) at /usr/share/perl5/Debconf/FrontEnd/Readline.pm line 7.)
debconf: falling back to frontend: Teletype
so thanks for all the fish 🙂
- Mark as New
- Bookmark
- Subscribe
- Permalink
Now fixed in ReadyNASOS 6.7.0-T180 (Beta 3). It's working perfectly.
