Reply
Follower
Phone calls dropping out after 20 seconds
[ Edited ]
We recently replaced our dlink router with the netgear wnr 2000. It works great for the laptops, printer, but not with the polycom ip430 phone. What happens is that when you make a call, you can talk for about 20 seconds, then there is no volume. It looks like the connection is still good, but you can't hear the other person and they can't hear you. If I try calling this phone from another phone, the polycom phone won't ring, but it will put you into voicemail. This phone was fine until moving to this new router ( the other one broke, so going back to that one is not an option ). Anyone have any ideas what could be going on?
Kathy
Luminary
Re: Phone calls dropping out after 20 seconds
put your voip on DMZ from the router interface and also disable SPI in the router interface
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
I have EXACTLY SAME PROBLEM - although my VOIP calls through VOIPCHEAP via a SIEMENS GIGASET S450IP device (static 192.168.1.8) and handset drop out after "24" seconds!!
As the GIGASET config page states VOIPCHEAP is not registered I presume that my WNR2000 is somehow blocking data through the port 5060??
Anyhow I have tried putting 192.168.1.8 in DMZ, port fowarding 5060 to the SIP device and disabling SPI but to NO AVAIL - am exhausted - but see many others on other forum sites have had same problem - oh I wish I knew the solution.
If I connect the SIP device directly to modem then registration succeeds and all is well. The WNR2000 needs a tweak somewhere??
Many many thanks
Novice
I have exactly the same problem. The call drops after 25 seconds. I'm using a GigaSet C450IP and a WNR2000 router. I tried a softphone - works fine. Plugging the C450IP directly into the internet connection also works fine. I had the C450IP connected to a DLink router for 2 years, and it worked fine - until yesterday when I replaced the DLink with Netgear.
Help!
I had the same problem and saw another post on how to fix it.
I have a Polycom SoundPoint 550 SIP IP Phone and a WNR2000 v1 router with Firmware Version 1.2.0.8. The phone would connect and then drop after 20 seconds.
I tried June Mizoguchi's suggestions of put your voip on DMZ from the router interface and also disable SPI in the router interface. Did not work.
The other post suggested downgrading the firmware to version 1.1.3.9. I tried it and now my IP Phone works just fine. Bonus, I did not have to disable SPI or put the phone on the DMZ.
I thought jmizoguchi was supposed to be the expert...
Luminary
who said I was expert????
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Novice
I've had more or less the same issues as above.
I've had a Siemens C450IP running happily on a wired D-Link (DI-604) router. I decided to finally go wireless and purchased a Netgear WNR2000 on Tues of this week (22nd Dec) and ever since all outgoing calls are disconnected at 20sec and incoming calls are intermittently affected but at alow rate.
I rang the netgear support number and the guy tried loading a number of firmwareversions but to no avail. The router was on 1.2.0.8 and I think he upgraded to 1.2.3.7 and claims to also have reverted back to 1.1.3.9 but calls still fail at 20secs.
After an hour the advice was that nothing further could be done and that I could try and take the router back and change it for a newer model WNR2000v2 or a different newer model of netgear.
To me it seems that Netgear simply cannot support home voip service on their routers and the best solution is to not buy Netgear!!! I'll be taking the WNR2000 back and asking for a replacement with some other manufacturer!!!
This does seem to be an issue - I have exactly the same problem.
Having had no problems for 12 months with a Siemens C450IP via an old Belkin router, I've installed a WNDR3700 and find all the VOIP calls are disconnected after 20 seconds.
As this is a new model router, I can't really follow advice to go for a newer model.
It's worth noting that I did not need to make any special settings for the old router to work - no DMZ, no port forwarding, it just worked.
So, is there any solution to this problem?
Thanks,
MarkP
I had the same problem with a new WNDR3700. In "WAN Settings" check on the "Disable SIP ALG" box under "NAT filtering"
Thanks for the tip Gerrycor, I'll give that a try.
MarkP
I purchased and installed a Grandstream HandyTone-286 this week, and the 20 second disconnect problem was driving me crazy until I found this forum. I tried changing multiple settings in the WNR200, including those mentioned on this page, and nothing worked. I finally downloaded firmware version 1.1.3.9 as suggested, and my outbound calls work fine now!
To anyone else having this problem, I strongly suggest doing this first, it will hopefully save you a lot of time.
Novice
I have just spend a couple of hours sorting out exactly the same problem with a SPA 3102 and Voip Cheap and the phone dropping after 25 secs. Downgrading the software to 1.1.39 also solved the issue completely for my WNR 2000 resolved this issue.
Now NETGEAR guys this is clearly a known issue so why have you not even posted it as such on the firmware download notes - presumably as you haven't even done that you have not got it in your development plan to resolve with your next firmware. This is not impressive - us customers and users deserve better.
SOLVED!!!
Got a polycom 330 phone using VOIP behind a NetGear WNR 1000v2 router. Outgoing calls would drop at exactly 20 seconds everytime. Did what Gerry said, problem solved! Smiley Very Happy
SOLVED!!!
Have a polycome 330 VOIP phone thats behind a NetGear WNR 1000v2 router. Outgoing calls would drop at 20 seconds everytime, did what Gerry says, its fixed! Smiley Very Happy
I have the Polycom 321 phone and a WNDR3700 router. I am having trouble with the phone rebooting anytime the phone tries to ring or if I push any of the buttons on the front except the number buttons or the menu. Can anyone help? I have already disabled the SIP ALG in the WAN settings. It didnt help.
Same problem here with the WNR2000v1 using Siemens / Gigaset N300A-IP (later version of C470IP) voip base station :mad:. That is the 20 second drop out period for voip calls. I simply downgraded to the WNR2000-V1.1.3.9.img file did not clear setting and re-enter and it works fine now...seems to have kept all setting and works fine. I did have to restart the N300A-IP after the firmware downgrade on the WNR2000v1 router. I wasted a whole day trying to reconfigure the router and N300/N300A-IP unit before I found these forum entries. Thanks everyone!Smiley Happy
hey, you can choose VOIP services because with using of VOIP devices you can getting many type of ideas to improve your working level.
Discussion Stats
  • 16 replies
  • 54074 views
  • 0 kudos
  • 14 in conversation
