Orbi WiFi 7 RBE973
Reply
Excessive fan noise
techmusic247
Follower
Excessive fan noise
Is there a way to reduce the fan noise on the SRX5308?  While running very cool, the fan noise is excessive and cannot be used in a quiet office environment.
Model: SRX5308|PROSAFE Gigabit Quad WAN SSL & IPSEC VPN Firewall
Message 1 of 3
JohnC_V
NETGEAR Moderator
Re: Excessive fan noise
Hi techmusic247,
Welcome to the community!
SRX5308 doesn't have any options to reduce the fan speed. It seems that this is already a hardware issue and I believe that this has a lifetime hardware warranty, then I may suggest you to please create a chat / case online on NETGEAR support and please let them know the status of your firewall so that an online replacement will be provided.
Message 2 of 3
JohnC_V
NETGEAR Moderator
@techmusic247,
I would like to have a follow up on this thread if you were able to request an RMA online. Please let us know if everything is ok now or you still need further assistance.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2821 views
  • 0 kudos
  • 2 in conversation
Announcements
