- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
FVS336Gv3 locks up and sometimes reboots
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi i have 3 fvs336gv3 routers all running 4.3.4-2 firmware these units are running vpn's with each other in a star configeration. i have one that is locking up/rebooting several times a day all of a sudden it stopped doing this for a period of about 3 weeks now it has started again one thing i noticed is the unit dosn't keep time it seams to lose time and gain time for no apparent reason anyone got any idear's
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: FVS336Gv3 locks up and sometimes reboots
Hello SWILLIS,
Welcome to the community!
Did the issue occur after you have upgraded the firmware to 4.3.4-2 or has it been having issues ever since? Did you perform a factory reset after updating the firmware?
Thanks,
- Mark as New
- Bookmark
- Subscribe
- Permalink
it hase been happening for probobly the last 3 firmware version and yes i have done a factory reset and reload after the last update. i found it seam to happen most in the morning could be because that is when the vpn is most active
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi SWILLIS,
It appears that the firewall experiences the issue under heavy load. Since you have already performed a hardware reset and updated the firmware a few times it is looking like a hardware issue is on the way. I suggest to contact support, it might need to be looked at further or be replaced.
Thanks,
- Mark as New
- Bookmark
- Subscribe
- Permalink
ok i will talk to to suport
- Mark as New
- Bookmark
- Subscribe
- Permalink
You might want to try to downgrade the firmware to the last version that worked without issues. Firmwares are like feature sets, each one is broken in some way and fixes things in some way--find the one that works for you and stick with it unless you have a reason to change it.
