Orbi WiFi 7 RBE973
Firewall settings for Chrome Remote Desktop
martinav
Guide
I need Chrome Remote Desktop to work ASAP.  It worked great until I installed a FVS336Gv3 firewall.  Its the 5th hour now, and still no joy.  I can see computers are online (outside my firewall), but attempts to connect fail from every PC in my network.  CRD works great on my internal network, so local settgs are fine.  Its not Kaspersky or Norton.  It has to be the firewall.  No other explanation.  I need instruction to allow CRD to pass.  The needed information from google:
Your computer's firewall may be configured in a way that doesn't let the app work properly. Verify that your firewall permits outbound UDP traffic, permits inbound UDP responses and allows traffic on TCP ports 443 (HTTPS) and 5222 (XMPP)
I have tried lots of combinations of rule settings in the firewall with no joy.  How the hell do you do it?
Thank you,
Rod
Model: FVS336Gv3|ProSafe dual WAN gigabit firewall with SSL and IPSec VPN
Message 1 of 7
Accepted Solutions
DaneA
NETGEAR Employee Retired
Re: Firewall settings for Chrome Remote Desktop
Hi martinav,
If ever you have already configured inbound firewall rules for TCP ports 443 (HTTPS) and 5222 (XMPP) on the FVS336Gv3 that points to the LAN IP Address of your PC, kindly verify if its really open by using an online port scanner like here.
Let us know the result.
DaneA
NETGEAR Community Team
Message 2 of 7
All Replies
DaneA
Hi martinav,
DaneA
Message 2 of 7
martinav
Guide
Nothing is open.  Not even 80.
The checked port (5222, service xmpp-client) is offline/unreachable
I have no idea if its even done right.  Lets start there.  This is where I left it after worthless hours of messing around with it:
192.168.157.103 is the internal IP of the PC i'm trying to use to connect to my external PCs.  Please advise...
Message 3 of 7
DaneA
@martinav,
It seems that you have configured the Services and the LAN WAN Inbound Rules properly.  Hope that the WAN IP Address registered on the FVS336Gv3 is a Public IP Address.
DaneA
Message 4 of 7
martinav
Guide
Well, does it matter, since I'm not trying to get IN my network, but I'm trying to connect OUTSIDE of my network.  This worked great before the firewall.  Does having the firewall in some way require some change in my outside IP address?  I would not think so.
Thoughts?
BTW, my outside IP is NOT static.
Message 5 of 7
DaneA
@martinav,
Since you want to remotely connect outside your network using Chrome Remote Desktop, then it seems that there is no need to configure LAN WAN Inbound Rules.  However, you might need it if ever there will come a time that you want to remotely connect to your network from outside using Chrome Remote Desktop.
Here are my questions below:
a. If you will connect your PC directly to the modem, are you able to remotely connect going outside your network using Chrome Remote Desktop?
b. Is your modem a modem-only device or a modem-router?
DaneA
Message 6 of 7
DaneA
@martinav,
I just want to follow-up on this.  We’d greatly appreciate your feedback.
DaneA
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 33979 views
  • 1 kudo
  • 2 in conversation
Announcements
