Reply
Help configuring IP phone through a FVS336GV2 router
I'm a newbe to the community so bare with me..
I'm trying to configure the FVS336GV2 to allow two IP phones to connect to my phone system. Previously I just opened a port on my windows server to get the job done. opened  UDP port 59301 pointed to internal IP 192.168.1.140 (phone card) and that worked like a charm.
Over the weekend I installed the router to handle incoming traffic and DHCP for the network, Setup services for incoming and outgoing IPphones with the same port and internal ipaddress, the external address is the same. Everything computer wise is working great but my phones cannot connect.
I'm sure i've missed something ...Help
Thanks Drummer544
NETGEAR Moderator
Re: Help configuring IP phone through a FVS336GV2 router
Hi Drummer544,
Welcome to the community! Smiley Happy
Kindly answer the questions below:
a. How is everything connected?  Are the IP phones directly connected to the FVS336Gv2?  Are the computer connected to the IP phones?  It would be best if you could post a diagram of your detailed network setup.
b. Is SIP ALG enabled?  To check, login the web-GUI of the FVS336Gv2 then go to Security > Firewall > Advanced.
c. What is the current firmware version of the FVS336Gv2?
DaneA
NETGEAR Community Team
DaneA,
The IP phones are offsite connected through a router (not netgear) and Cable modem. On the network side we're running through glass to a wide open Adtran router then the FVS336GV2., HP switches to the network which includes the KSU with a IP phone card..
( I will get you a Diagram - Sorry)
2. Sip/ALG - Disabled
3. not sure of the firmware - but I'm upgrading it as I type..
I've pulled the FVS for now because I needed to get my off site people up and running...Put in an old D-Link, opened the 59301 port, forwarded to my IP card.. We are working again.
Temporary fix for now! I want this Dual WAN
Thanks for your help!!
Drummer544
NETGEAR Moderator
[ Edited ]
@Drummer544,
I just want to follow-up on this.  Kindly post a diagram of your detailed network setup.
You mentioned that you were upgrading the firmware of the FVS336Gv2, to what firmware version have you upgraded the FVS336Gv2?  Be reminded to perform a factory reset after upgrading the firmware then reconfigure it from scratch.
DaneA
NETGEAR Moderator
@Drummer544,
I just want to follow-up on this again.  We’d greatly appreciate your feedback.
DaneA
Discussion Stats
  • 4 replies
  • 285 views
  • 0 kudos
  • 2 in conversation
Top Contributors
User Kudos Count
1
1
1
