Orbi WiFi 7 RBE973
Reply
Netbios wont work Box to Box VPN SRX5308 to FVS318N
RoyDerksen
Hi all,
Did setup a box to box IPSec VPN. The SRX5308 has WAN ip and the FVS318N is behind NAT but DMZ.
Its working so far so good, i can ping other devices but i cant acces any HTTP or HTTPS exept my server. Server is also WINS.
Can acces the shares to my NAS but cant acces his config page on HTTPS.
Can scan network and it finds most devices, portscan shows acceble ports 80, 443, etc.
Want to connect my dreambox on port 80 but wont open.
Can someone help me?
Roy
Model: FVS318N|ProSafe Wireless N 8 port gigabit VPN firewall,SRX5308|PROSAFE Gigabit Quad WAN SSL & IPSEC VPN Firewall
Message 1 of 9
DaneA
NETGEAR Employee Retired
Re: Netbios wont work Box to Box VPN SRX5308 to FVS318N
Hi RoyDerksen,
Welcome to the community! 🙂
Kindly answer the questions below:
a. Is the LAN subnet of the SRX5308 different from the LAN subnet of the FVS318N?
b. Is the WINS server directly connected to the SRX5308 or to the FVS318N?
c. Is NetBIOS enabled on the VPN Policy of both SRX5308 and FVS318N?
d. Have you tried to delete the existing IKE / VPN Policies then re-create it using the VPN Wizard on both SRX5308 and FVS318N?
e. What is the current firmware version of both SRX5308 and FVS318N?
f. Is your NAS a NETGEAR device?  If yes, what is the model number of it?
It would be best if you post a diagram of your detailed network setup as well as the settings of the IKE / VPN policies on both VPN firewalls.
DaneA
NETGEAR Community Team
Message 2 of 9
DaneA
@RoyDerksen,
I just want to follow-up on this.  We’d greatly appreciate your feedback.
DaneA
Message 3 of 9
RoyDerksen
Hi DaneA,
The answers  are:
a: Yes. LAN subnet of the SRX5308 192.168.2.0 and LAN subnet of the FVS318N 192.168.1.0
b: Yes. WINS server directly connected to the SRX5308, some other devices connected on switch JGS524
c: Yes on both sides NetBIOS enabled
d: Yes, did use wizard at both sides but wont work so playd a little around whitout succes
e: Firmware version of SRX5308 4.3.4-2 and FVS318N also the latest
f: My NAS is NOT a NETGEAR.
SRX5308
From the FVS318N its almost the same, identifier and start IP's are vice versa.
Message 4 of 9
DaneA
@RoyDerksen,
I apologize for this is the only time I got back on this.  Here are my follow-up questions:
a. Is the WINS server configured to the client on the FVS318N side also?
b. Can you confirm if NetBIOS does resolve between clients (such as PCs) on the same LAN?  For example: PC1 to PC2 within the FVS318N LAN or PC1 to PC2 within the SRX5308 LAN.
DaneA
Message 5 of 9
RoyDerksen
@DaneA
No problem, struggeling almost a mounth or 2 with this isue.
a. Yes, IP's are manual added to the wins server and seen as active.
b. Yes, both sides netbios works fine on all devices.
Maybe helps this: When i'm at work and i make a PPTP connection to SRX5308 with my phone (connected at the WiFi of the FVS318N) than all works fine, but only on my phone. When i use my laptop on PPTP dito.
Regards
Message 6 of 9
RoyDerksen
@DaneA
Nevermind this isue.
After latest firmware update the FVS318N wont boot up anymore.
Test led stays on. 😞
Message 7 of 9
DaneA
@RoyDerksen,
Have you tried to perform a factory reset on the FVS318N?  If yes and still the test LED is lit up, I suggest you to open a chat / online case with NETGEAR Support.  Let them know what happened to your FVS318N.  Attach a .pdf or .doc copy of the Proof of Purchase or Sales Invoice of the FVS318N on the online case for warranty verification.  If ever the hardware warranty is still valid, an online replacement will follow.
DaneA
Message 8 of 9
RoyDerksen
@DaneA
Yes, i did try several things to acces the FVS318N but nothing works.
Il bought this on second hand so no Proof of Purchase
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 4950 views
  • 0 kudos
  • 2 in conversation
Announcements
