Antworten
SRX5308 nicht nachvollziehbare Protokolleinträge
Idss
Hallo,
ich hatte am 16.2. Einträge im täglichen Protokoll für die ich nicht nachvollziehen kann:
[SRX5308]Sat Mar 16 19:23:52 2019((GMT+0100)) [SRX5308][SSLVPN][SSLVPN] SSL_ERROR: Invalid Password for user myxxxx';INSERT INTO USERDBUsers(UserName,FirstName,LastName,GroupName,UserType,UserTimeOut,groupid,DenyLogin,DenyLoginFromWan,LoginFromIP,LoginFr
mBrowser,Password,DefaultUser,LockoutEnable,MaxLockou
[SRX5308]Sat Mar 16 19:23:52 2019((GMT+0100)) [SRX5308][System][LOGIN] SSL_ERROR: Invalid Password for user myxxxx';INSERT INTO USERDBUsers(UserName,FirstName,LastName,GroupName,UserType,UserTimeOut,groupid,DenyLogin,DenyLoginFromWan,LoginFromIP,LoginFro
Browser,Password,DefaultUser,LockoutEnable,MaxLockout
[SRX5308]Sat Mar 16 19:23:53 2019((GMT+0100)) [SRX5308][SSLVPN][SSLVPN] Administrator app is successfully added. Group: geardomain User TimeOut: 5
[SRX5308]Sat Mar 16 19:23:55 2019((GMT+0100)) [SRX5308][SSLVPN][SSLVPN]  SSL_INFO : Login Successful for geardomain user app(Admin) from host 161.129.70.221
[SRX5308]Sat Mar 16 19:23:55 2019((GMT+0100)) [SRX5308][System][LOGIN]  SSL_INFO : Login Successful for geardomain user app(Admin) from host 161.129.70.221
[SRX5308]Sat Mar 16 19:24:11 2019((GMT+0100)) [SRX5308][SSLVPN][SSLVPN] SSL_INFO :user app is Logged-Out successfully from host 161.129.70.221
[SRX5308]Sat Mar 16 19:24:11 2019((GMT+0100)) [SRX5308][System][LOGIN] SSL_INFO :user app is Logged-Out successfully from host 161.129.70.221
[SRX5308]Sat Mar 16 19:24:11 2019((GMT+0100)) [SRX5308][SSLVPN][SSLVPN] SSL_ERROR: Invalid Password for user myxxxx';delete from USERDBUsers where UserName='app';'
[SRX5308]Sat Mar 16 19:24:11 2019((GMT+0100)) [SRX5308][System][LOGIN] SSL_ERROR: Invalid Password for user myxxxx';delete from USERDBUsers where UserName='app';'
[SRX5308]Sat Mar 16 19:24:12 2019((GMT+0100)) [SRX5308][SSLVPN][SSLVPN] Deleted User app
Bin dankbar für jede Info,
mfG
Schildberg Dieter
Model: SRX5308|PROSAFE Gigabit Quad WAN SSL & IPSEC VPN Firewall
Nachricht 1 von 11
Akzeptierte Lösungen
FrankHe
NETGEAR Employee Retired
Re: SRX5308 nicht nachvollziehbare Protokolleinträge
Hallo @Idss,
dann wären wir hier in der Community leider am Limit dessen angekommen was wir tun können.
Ich würde dich bitten, unseren Telefon Support hier zu kontaktieren. Die Kollegen haben evtl. die Möglichkeit sich auf zu schalten um zu sehen wo das Problem liegt.
Mit freundlichen Grüßen
FrankHe
Team NETGEAR
Lösung in ursprünglichem Beitrag anzeigen
Nachricht 10 von 11
Alle Antworten
FrankHe
Hallo @ldss,
willkommen in der NETGEAR Community.
Die Einträge sagen nur aus das sich jemand versucht hat ein zu loggen aber das PW falsch war. Weiter unten war der Login dann von der IP 161.129.70.221 erfolgreich.
Noch weiter unten dann wieder nicht.
FrankHe
Team NETGEAR
Nachricht 2 von 11
Idss
Hallo FrankE,
das Problem ist nur, dass ich keinen User ‚app‘ angelegt habe???
MfG
Schildberg
Nachricht 3 von 11
FrankHe
Hallo @ldss,
leider kann ich dir nicht sagen was in deinem Netzwerk los ist.
Sagt dir die IP Adresse etwas? Welche Geräte sitzen hinter der Firewall?
NAS etc. ?
FrankHe
Team NETGEAR
Nachricht 4 von 11
Idss
Hallo FrankHe,
ich hab ein Subnet mit 192.168.200.xxx hinter der Firewall: 6 Rechner, 1 Server, 4 Cams, 1 Drucker, WLAN's, VOIP-Telefone...
Die IP 161.129.70.221 ist also eine externe, lt. IN  'quadranet.com'.
Ich log mich lokal über 'admin' mit geändertem Passwort ein und 'admin' hat keinen Zugang über ein WAN, 'guest' überhaupt keinen.
Dann gibts noch 'idss' einen PPTP-User.
Remote-Management habe ich inzwischen deaktiviert.
Das ist doch etwas misteriös.
mfG
Schildberg
Nachricht 5 von 11
FrankHe
Hallo @ldss,
leider können wir da wenig helfen, wer Zugang zu deinem System hat.
Wie bereits gesagt, die Log's zeigen nur das jemand von der IP 161.xxxxxxx Zugang hatte.
FrankHe
Team NETGEAR
Nachricht 6 von 11
Idss
Hallo FrankHe,
wenn sich jemand an meinem Router mit einem User anmelden kann, den ich nicht angelegt habe, dann läßt das nur einen Schluss zu, nähmlich, dass es in dem Router einen unsichtbaren User/Zugang gibt, was wohl das Gegenteil eines Sicherheitskriteriums darstellt. Mit anderen Worten: eine Sicherheitslücke. Und wer bitte sollte da helfen?
mfG
Schildberg
Nachricht 7 von 11
FrankHe
Hallo @ldss,
wie es aussieht kommt der login über ein SSL VPN.
Gibt es einen SSL User "App" und besteht eine aktive SSL VPN policy die ein login erlaubt?
FrankHe
Team NETGEAR
Nachricht 8 von 11
Idss
Hallo FrankHe,
eben nicht.
mfG
Schildberg
Nachricht 9 von 11
FrankHe
Hallo @Idss,
FrankHe
Team NETGEAR
Nachricht 10 von 11
KngDa
I had exactly the same log entry on March 17th. There is no one authorized to be logging in. It looks like the app was successfully installed. There was also a successful login on March 18th. I can't see anything in the configuration of the router. As I can't take the security risk, I am replacing the router with a more current model.
Nachricht 11 von 11
Diskussionsstatistiken
  • 10 Antworten
  • 4834 Aufrufe
  • 0 Kudos
  • 3 in Unterhaltung
