Orbi WiFi 7 RBE973
Reply
SRX5308 web portal hangs
csg_wro
Hello,
From time to time web interface hangs for about 1-3 min. The page is just loading, I cannot connect to telnet during freeze, but router is generally working (LAN routing).
- I tried to minimize the number of open tabs of web interface (with 1 it also happens),
- I noticed that this happens not only for POST request (saving settings), but also while browsing (GET),
- I tried also minimize the number of logged users (I was the only one), and this also happens.
I am using HTTPS to browse web portal.
I upgraded the firmware to: 3.0.8-12
Screen 1 (POST): http://img515.imageshack.us/img515/262/developertoolshttps1921.png
Screen 2 (GET): http://img547.imageshack.us/img547/9459/zaznaczenie044.png
Message 1 of 8
jmizoguchi
Virtuoso
Re: SRX5308 web portal hangs
Is this something after you flash to this firmware version?
Message 2 of 8
csg_wro
No. I bought the hardware with 3.0.7-45 and because of that problem I upgraded the firmare which does not solved my issue.
Message 3 of 8
jmizoguchi
Virtuoso
if you upgraded then hard reset and manually configure it
Message 4 of 8
csg_wro
I see that it is a standard reply SRX5308 web portal hangs when anybody could help. I did not do a "hard reset", but I have restored to factory default. And nothing changed (later read changelog, which modifies nothing in this matter).
Message 5 of 8
jmizoguchi
Virtuoso
If you restore router config , try reset /factory default and don't restore back
Message 6 of 8
csg_wro
PS. sorry for unintended pasting thred title in the middle of post. I cannot edit it now.
Message 7 of 8
csg_wro
@jmizoguchi: Thanks, I will try as it is the only hope.
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 12762 views
  • 0 kudos
  • 2 in conversation
Announcements
