Orbi WiFi 7 RBE973
Reply
Srx5308
Zakzak20
Follower
Srx5308
Hi,
I am trying to set up a srx5308 so that Wan1 is the main connection, with a dsl connection for wan2 rollover. Wan2 connects to the internet when there is a direct wired connection, but if I remove wan1, Wan2 goes down too. I would like Wan2 to maintain connection if/when wan1 goes down.
Thanks
Model: SRX5308|PROSAFE Gigabit Quad WAN SSL & IPSEC VPN Firewall
Message 1 of 3
JohnC_V
NETGEAR Moderator
Re: Srx5308
Hi Zakzak20,
Welcome to our community!
WAN Rollover may take about a minute before it goes up. If you notice in the admin page, WAN 2 is down if it is set to rollover. It will not show any WAN IP unless you remove the cable from WAN 1. Does the WAN 2 port lights up right after you remove the cable from WAN 1? Please make sure that the firmware is up to date. If it's still not working right after the firmware update, you may try resetting it to factory default and reconfigure the rollover feature again.
You may check this documentation for reference.
Message 2 of 3
JohnC_V
NETGEAR Moderator
Re: Srx5308
@Zakzak20,
I would like to have a follow up on this thread. Please let us know if everything is ok now or you still need further assistance.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1089 views
  • 0 kudos
  • 2 in conversation
Announcements
