Orbi WiFi 7 RBE973
VPNG05L need licence keys reset
dkcarl
Past hardware failures have consumed our licenses and only 1 of 5 seems to be working. Please reset the license keys associated with my account. Thanks in advance.
Model: FVS318N|ProSafe Wireless N 8 port gigabit VPN firewall
Message 1 of 3
Accepted Solutions
DaneA
NETGEAR Employee Retired
Re: VPNG05L need licence keys reset
@dkcarl,
I just got a feedback from the higher tier of NETGEAR Support that your all of the 5-user VPN license keys have been reset.  Kindly check it on your end.
If ever your concern has been resolved and you have no further inquiries, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
NETGEAR Community Team
Message 3 of 3
All Replies
DaneA
Hi @dkcarl,
Kindly send me the following below via private message:
a. the VPN license key that needs to be reset
b. e-mail address/es that was used when you have registered the VPN license key
DaneA
Message 2 of 3
DaneA
@dkcarl,
DaneA
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1468 views
  • 1 kudo
  • 2 in conversation
Announcements
