Orbi WiFi 7 RBE973
Reply
i am trying to connect an n300 wireless to netgear 8 port model #fvs318g
ok1234
Follower
using n300 wireless to connect printer to my 8 port firewall fvs318g, just get a flashing amber light on 8 port router. 8 port router is connect to cable modem and connectig froa a port on 8 port to a data port on wireless using regular patch cable.
would appreciate any help offered.
thanks
ok1234
Message 1 of 3
DaneA
NETGEAR Employee Retired
Re: i am trying to connect an n300 wireless to netgear 8 port model #fvs318g
Hi ok1234,
Welcome to the community! 🙂
Are you referring to the Test LED of the FVS318G that is flashing amber?  If yes, kindly try to reset the FVS318G back to factory default setting then check if the Test LED is still flashing amber.
If ever the Test LED is still flashing amber after doing a factory reset on the FVS318G, then it means that the device has failed.  I suggest you to open a chat / online case with NETGEAR Support and let them know the status of the FVS318G.  Attach a .doc or .pdf copy of the Proof of Purchase or Sales Invoice of the FVS318G on the chat / online case for warranty verification.  If ever the hardware warranty is still valid, an online replacement will follow.
DaneA
NETGEAR Community Team
Message 2 of 3
DaneA
@ok1234,
I just want to follow-up on this.  We’d greatly appreciate your feedback.
DaneA
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2969 views
  • 0 kudos
  • 2 in conversation
Announcements
