Reply
RBR40 Create Network after factory reset
rickcb
Follower
I have an RBR40 Orbi Router that I had to do a factory reset on.  Now I am unable to re-establsi my network.  When I do a speed test via my phone when connected to the wifi it doesn't get past 3 Mps.  I am unable to sign into the orbi app for the router as it won;t take the default password (password).  I do not have the original instructions and feel I am just not doing the basic steps correctly.
Simple set of orbi router plugged into std FiOS gateway with 3 satellites.  All worked well for over a year, until I was having problems with what I thought was the Orbi but turned out to be a Gateway issue, but by then I had already done the factory reset on the orbi.
Any help or instructions would be appreciated.
RickB
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 1
Discussion stats
  • 0 replies
  • 656 views
  • 0 kudos
  • 1 in conversation
