- RSS-Feed abonnieren
- Thema als neu kennzeichnen
- Thema als gelesen kennzeichnen
- Diesen Thema für aktuellen Benutzer floaten
- Lesezeichen
- Abonnieren
- Drucker-Anzeigeseite
Hilfe mit WNR 2000v4 unterbricht Internet Verbindung alle 2 Stunden
- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
Habe alles mögliche versucht, zB idle time out auf 0 gesetzt, aber nutzt alles nichts, der Router verbindet sich pünktlich alle 2 Stunden neu.
[Internet connected] IP address: xxxxxxxx, Sunday, September 04, 2016 19:07:45
[Internet disconnected] Sunday, September 04, 2016 19:07:30
[Internet connected] IP address: xxxxxxxxx , Sunday, September 04, 2016 17:07:45
[Internet disconnected] Sunday, September 04, 2016 17:07:30
[Internet connected] IP address: xxxxxxxxxx , Sunday, September 04, 2016 15:07:45
[Internet disconnected] Sunday, September 04, 2016 15:07:30
[Internet connected] IP address:xxxxxxxxxx , Sunday, September 04, 2016 13:07:45
[Internet disconnected] Sunday, September 04, 2016 13:07:30
[Internet connected] IP address: xxxxxxxxxx, Sunday, September 04, 2016 11:07:45
[Internet connected]IP address: xxxxxxxx , Sunday, September 04, 2016 09:07:45
[Internet disconnected] Sunday, September 04, 2016 09:07:30
[Internet connected] IP address: xxxxxxxxxx , Sunday, September 04, 2016 07:07:45
[Internet disconnected] Sunday, September 04, 2016 07:07:30
[Internet connected] IP address: xxxxxxxxxx , Sunday, September 04, 2016 05:07:45
[Internet disconnected] Sunday, September 04, 2016 05:07:30
[UPnP set event: del_nat_rule] from source 192.168.1.2, Sunday, September 04, 2016 03:03:29
[UPnP set event: add_nat_rule] from source 192.168.1.2, Saturday, September 03, 2016 21:39:33
[Time synchronized with NTP server] Saturday, September 03, 2016 19:22:55
[Internet connected] IP address: xxxxxxxxxx Saturday, September 03, 2016 19:22:37
[Initialized, firmware version: V1.0.0.64] Saturday, September 03, 2016 19:21:33
Ist das eine fehlerhafte Firmware oder kann ich das vielleicht doch irgendwie einstellen dass er das nicht mehr macht?
PS: Habe das auch aus Versehen im englischen Forum gepostet, vielleicht kann man das dort löschen.
Danke.
- Lesezeichen
- Abonnieren
- Kennzeichnen
wnr 2000v4 disconnects every 2 hours
Hi, I'm having this problem since a while now, I tried everything I could think of, but the router keeps disconnecting from internet every 2 hours and then connects again within 15 seconds.
[Internet connected] IP address: xxxxxxxx, Sunday, September 04, 2016 19:07:45 [Internet disconnected] Sunday, September 04, 2016 19:07:30 [Internet connected] IP address: xxxxxxxxx , Sunday, September 04, 2016 17:07:45 [Internet disconnected] Sunday, September 04, 2016 17:07:30 [Internet connected] IP address: xxxxxxxxxx , Sunday, September 04, 2016 15:07:45 [Internet disconnected] Sunday, September 04, 2016 15:07:30 [Internet connected] IP address:xxxxxxxxxx , Sunday, September 04, 2016 13:07:45 [Internet disconnected] Sunday, September 04, 2016 13:07:30 [Internet connected] IP address: xxxxxxxxxx, Sunday, September 04, 2016 11:07:45 [Internet disconnected] Sunday, September [Internet connected]IP address: xxxxxxxx , Sunday, September 04, 2016 09:07:45 [Internet disconnected] Sunday, September 04, 2016 09:07:30 [Internet connected] IP address: xxxxxxxxxx , Sunday, September 04, 2016 07:07:45 [Internet disconnected] Sunday, September 04, 2016 07:07:30 [Internet connected] IP address: xxxxxxxxxx , Sunday, September 04, 2016 05:07:45 [Internet disconnected] Sunday, September 04, 2016 05:07:30 [UPnP set event: del_nat_rule] from source 192.168.1.2, Sunday, September 04, 2016 03:03:29 [UPnP set event: add_nat_rule] from source 192.168.1.2, Saturday, September 03, 2016 21:39:33 [Time synchronized with NTP server] Saturday, September 03, 2016 19:22:55 [Internet connected] IP address: xxxxxxxxxx Saturday, September 03, 2016 19:22:37 [Initialized, firmware version: V1.0.0.64] Saturday,September 03, 2016 19:21:33
The connection is set to "always on" and I've set idle time out to 0 anyways to test if it helps, but it didn't do anything, it still disconnects me every 2 hours seemingly while idling.
Note: It didn't do that during the first week of use, but since then it does it all the time.
Any suggestions?
Thanks!
- Lesezeichen
- Abonnieren
- Kennzeichnen
Re: Hilfe mit WNR 2000v4 unterbricht Internet Verbindung alle 2 Stunden
Hallo @sums_et,
erstmal herzlich Willkommen in der NETGEAR Community!
Fünf Informationen wären in Deinem Fall für uns wichtig:
1. Gibt es das Problem von Anfang an?
2. Ist die Störung nach dem Firmware Update aufgetreten?
3. An was für ein Gerät ist der WNR angeschlossen? Ist das ein Modem oder Modemrouter?
4. Was für einen Internetanbieter hast Du?
5. Wie ist der WNR konfiguriert (als Router oder Access Point)?
PS: Ich habe Deinen Beitrag in den Thread verschoben 🙂
Viele Grüße
Sylvia
NETGEAR Team
- Lesezeichen
- Abonnieren
- Kennzeichnen
Hallo,
1. Nein, komischerweise hat in der ersten Woche alles einwandfrei funktioniert, aber seit dem, also seit ca.2 - 3 Wochen macht er das ständig, wie man sieht alle 2 Stunden.
2. Die Firmware ist auch dieselbe, die ist schon seit mehreren Monaten drauf.
3. Der WNR ist an ein Zyxel -1312-B30A das im Bridge Modus läuft angeschlossen.
4. Anbieter ist 1&1 und der WNR ist als Router konfiguriert.
Habe auch testweise eine Fritzbox im Router Modus am Zyxel angeschlossen, die macht das nicht mit den ständigen Neueinwahlen. Und es ist alles über LAN Kabel verbunden, das ist vielleicht auch noch wichtig.
Wie gesagt die erste Woche lief alles so wie es sollte. Seit dem nicht mehr, sieht man ja in den Log Einträgen.
- Lesezeichen
- Abonnieren
- Kennzeichnen
Hallo @sums_et,
gehe bitte noch unter Internet Einstellungen, wo Du die Zugangsdaten von Deinem ISP eingetragen hast und stelle statische DNS Adressen ein:
- primäre DNS Adresse: 8.8.8.8
- secondäre DNS Adresse: 4.2.2.2
Wird das nicht behilflich sein, dann bringe das Gerät (den Reset-Knopf bitte 20-30 Sekunden lang gedrückt halten, bis die Power LED orange aufleuchtet) auf Werkseinstellungen zurück und konfiguriere es manuell erneut.
Viele Grüße
Sylvia
NETGEAR Team
