openvpn 证书问题
openvpn 证书问题
第一台R9000,升级固件1.0.3.10后,openvpn证书丢失,导致不能使用vpn。
官方客服换了一台新机,并告知我1.0.3.10有bug,可以使用1.0.3.6,于是把第二台R9000升级到1.0.3.6,证书没有丢失,但是过期了,过期时间是1902年。
降级固件也没用,证书不更新,一直是过期的证书。
现在客服没有给出解决方案,也不能给解决,只说向研发报bug。
我花了3000元买了一个全世界最牛逼的路由器,现在出问题没人给解决。
我一次一次的电话邮件沟通,刷新各版固件,无偿的为你们做测试,现在没有任何一个人能给我一个明确的答复,只跟我说抱歉。
Re: openvpn 证书问题
Hi @Miadi
To the extent I think I understand Chinese your R9000 has a certificate with an expiration date in 1902. No idea what can cause this - seen at least one more similar report some days ago here in the community.
The Nighthawk firmware does usually come with a factory (hard coded) certificate, signed by Entrust, that's the one I have in place since 1.0.3.10 - conclude, there is a problem with some, but by far not all R9000 updated:
This kind of factory certificate is also the reason why older firmware - which held indeed an expired certificate (but not back as far as 1902) - can't be used anymore.
Digging again with the Netgear product engineer.
(Edit:)
If you have a minute - please download the OpenVPN Windows config from your R9000, unzip, and open (double click) ca.crt and client.crt - post the certificate overview and details.
The older certificate set was valid from 25-APR-2014 ... 22-APR-2024, the one I have here on my R9000 is valid from 26-APR-2017 to 21-APR-2037. Curious about yours.
(Edit end.)
-Kurt
PS. Take this as another complaint @AbhayB and @NaderA - it's ridiculous how unreliable your supposedly leading edge (and expensive!) products are.
回复: openvpn 证书问题
Re: openvpn 证书问题
更新到1.0.3.6,openvpn的证书日期就会变成 2018年12月1日 - 1902年x月x日,不仅仅是ca.crt/client.crt/client.key,server的证书也如此,cat一下easy-rsa中的所有文件,日期都是如此。。
现在我修改了一下vars,和服务器时间,只生成10年的,截止日期就不会变成1902年了。
具体方法在上面的附件中。
回复: openvpn 证书问题
This is R9000-V1.0.3.16.img image is identical to the one I have received from Netgear for testing - bit by bit, and same md5 checksum.
Further on it does come with the updated dnsmasq.
回复: openvpn 证书问题
固件升级1.0.3.16,复位,证书并没有升级,还是之前1.0.3.6我自己生成的证书,TCP连接不了VPN,UDP未测试。。
在1.0.3.16中又重新生成证书,TCP一样连接不了,UDP可以连接。
我现在把固件降级成1.0.3.6,用1.0.3.16中生成的证书就可以用TCP连接了。
偌大个网件,一个openvpn证书都整不明白,我也是醉了。看来还是用华硕吧,网件太垃圾了。
