Reply
Default Password WGR614v9
I have had this problem with this router. I cannot access it as i need the password. I have read forums and they say the default password and username is Admin(User) and password(pass). I have tried this and still nothing. I have even hit the reset button on the router and still cannot access it. Pls does anyone have this router to help me out
Re: Default Password WGR614v9
I would download the quick start sheet or user manual for the router from the link at the top of this page. On some routers the default password is 12345 or admin.
Luminary
make sure the reset is done correctly
see "router reset" on my signature. step 1,3
if these don't work..
is your router provided by ISP? there are few that I seen has custom firmware that makes whole issue different. in that case you may want to consult your ISP..
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
I think it might just be a custom firmware as i got it with a virgin broadband deal. I will contact them. Thanks for the help.
Look on the bottom of the router, (I didn't, took me ages to find the info on the net lol)
Address: 192.168.1.1
User: virgin
Password: password
Disabling wireless:
If anyone wants to disable the wireless side like I did uncheck the 'Enable wireless router radio' box.
Luminary
User: virgin
Password: password
Disabling wireless:
I take you ISP is Virgin?
apparently some router other ISP Sky also uses different user/pass.
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Yeh, im with virgin
User: virgin
Password: password
Disabling wireless:
Thanks for that! Since the name of the wireless network is Virgin blablabla, I figured this must be the right details - and they are =]
my WGR614v9 router did not have the log-in info listed on the bottom and the ones listed here did not work :eek: so I looked it up and found this default WGR614v9 username and password which worked like a charm
i hope this fixes your woes too! Smiley Happy
Luminary
That is default for Netgear and its is in manual but other ISP branded firmware is not the same
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Discussion Stats
  • 9 replies
  • 135925 views
  • 0 kudos
  • 6 in conversation
Top Contributors
User Kudos Count
1
