Reply
No Internet Connection with Airport Extreme
I have the Netgear wnce2001 wireless adapter that I connect to my tv to access Youtube and other content the tv provides. It's been working great until swapped out my old Linksys router for a Apple Airport Extreme (I use an iMac desktop).
It will not connect to my network. It has the latest firmware, 1.0.0.26, so I'm wondering anyone else had this problem, and how did they resolve it.
tks,
Luminary
Re: No Internet Connection with Airport Extreme
what setting , what encryption and what MODEL of the router
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
It's the Apple Airport Extreme 802.11n, model A1408
encryption WPA/WPA2, 128-bit WEP Security
not sure what "setting" you're looking for; let me know, tks.
Luminary
which one are using?
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
I'm using WPA2...thanks..
Luminary
with what router
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
What router?? The Apple Airport Extreme...
Luminary
airport extreme base station.... that is full router name.
airport extreme can be mistake by extreme airport card. Smiley HappySmiley Happy
hard to say but this could be both at apple and netgear not just adapter issues since it did work with linksys.
if you are using WPA2 then passphrase you choose should have wired. I would try WPA
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
It's all good....I changed the setting to wpa/wpa2, and now everything is "wirelessly" in sync.
tks,!!
Luminary
enjoy it....Smiley Happy
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Discussion Stats
  • 9 replies
  • 5316 views
  • 0 kudos
  • 2 in conversation
Top Contributors
User Kudos Count
1
