Reply
Follower
Unable to login to http://www.routerlogin.net
Hello,
I am using netgear from 3 months, the wifi connection is fine, but i have forgot the user id and password for "http://routerlogin.net" . Now i need to change "wireless Network Name(SSID)" and "Wireless Security Passphase" . It is possible only by restoring the user ID and password . Please help me to solve this problem Smiley SadSmiley SadSmiley SadSmiley Sad
Tutor
Re: Unable to login to http://www.routerlogin.net
Hi,
The default username is admin and password is password. If its still not letting you login to the page. You might have to set the product to Factory defaults.
Luminary
likely that this very old unit router but
older router uses
user admin
pass 1234
doubtfully it is but if admin/password do not allow, reset is the only way
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
I am experiencing a similar problem. I logged into routerlogin.net. When prompted to check for updates, I clicked on the box. After taking this action, I could not log back into the router page by either typing routerlogin.net, routerlogin.com, or the router's IP address.
What happened when I clicked on the box to check for updates to my 2009 Netgear router WNR3500 and why is it that my computer cannot find routerlogin.net? I have wifi connection because I am able to use my gaming console (i.e., Xbox 360 Live).
Must I reset to factory default? If yes, then should I first write down the MAC addresses to the equipment/components that were on my list of devices approved for wireless connection through my router?
Also, which password should guests enter to gain wifi access - is it the passphrase, not the administrator's password, right?
Luminary
Reset router after flashing firmware
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Hi. Thanks for your reply.
What do you mean by "flashing firmware?" Can you send me instructions to do this or send me a link for firmware compatible with WNR3500?
When searching for latest version, I found this: wnr3500_1_1_15_1_0_14_na_only.chk but I could not open it
Luminary
flahsing firmware.. upgrading firmware.. same thing.
flashing is actually the correct lingo..
go to support.netgeasr.com and look up your model. firmware is under download tab once you are in the product support page
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
I cant enter routerlogin.net.how can i enter this.plzz rpyy
Luminary
You posted 2years post.
Post a new thread of your own under router section
http://forum1.netgear.com/forumdisplay.php?f=28
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Discussion Stats
  • 8 replies
  • 444416 views
  • 4 kudos
  • 5 in conversation
Top Contributors
User Kudos Count
1
