Reply
Novice
Universal WiFi internet adapter (wnce2001) help!
Hello, i need some help. i have just baught this adapter and tried many times now and i dont get any wireless internet. so i hope u can help me!
I do as it says, im disconeccting everything and plugs in my adapter to powers. it gets green and i put my included ethernet cabel, and it gets green too. open my browser and follows the instructions on the setup page. and i come to this site where i have to write "name" and "key" and then i get lost! what name and key? shall i make up one, or do i have to use one they have upstairs? i dont know if they have one, because i am renting at someplace, and they just have a internetcabel down here.
And then i try this other thng, instead of putting the included ethernet cable in the adapter, i put the internet cable from upstairs in. but then i cant open the browser! so i have no idea what i shall do. :
Hope u can help me!
Luminary
Re: Universal WiFi internet adapter (wnce2001) help!
Windows 7
Plugs USB power adapter and plug provided ethernet cable to the WNCE2001
Once the Power LED is solid green, unit is "GOOD"
Open the browser and should open URL http://www.mywifiext.come/welcome.htm
Choose language
Hit next and it will go through status bar and look for "available" wireless network with following
SSID name
Channel
Security type
Signal Strength
It also includes "manually input my wireless SSID" for use who hides broadcasting of SSID
Choose your SSID and hit next
Provide your pass phrase and hit next
It will go through the status bar for connecting to the wireless router. After 1~2min it should come up with "You have successfully connected to wireless SSID NAME "
HIt finish. It will also ask you to save to your browser's favorites list. Close the the browser and open browser again
If you are using Win 7 it will ask your "network location" you can close or specify the type and save it
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Novice
i have done all this. but i dont know what SSID is.. and im not getting past the "name" and "key (password)" site. it doesnt find wireless internet..
Luminary
should find your existing wireless network
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Novice
but when you say existing wireless. im not following. cause i dont have wireless network. thats the adapter i have bought? thats the wireless network..? isnt it?
Luminary
???? if you do not have your own wireless ROUTER or existing wireless network then WNCE2001 will never find it wireless. this adapter and not router or gateway to provide internet access
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Novice
omg! then the man i bought it from didnt understand what i wanted! i said to him i wanted a router, cause i wanted wireless internet instead of cabel. and he sold me this one. and its not a router!? thats bad service. :/ god.
Luminary
you will need a wireless router and not wireless ADAPTER
depending on type of broadband you have but you can pick router like wndr3700, wnr2000, etc.
product that starts D is for DSL modem built-in wireless gateway
product that starts C is for Cable modem built-in wireless gateway
Most prefer just wireless router and install behind the broadband modem you have already but this just preference and makes not much difference is performance... two boxes or one boxes is all you need to know in basic manner.
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Novice
thank you so much for the help. i just going to return that adapter and by me a router. Smiley Happy
Luminary
good luck... if does not say wireless gateway, or wireless router then you got wrong one.. lol
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Discussion Stats
  • 9 replies
  • 3693 views
  • 0 kudos
  • 2 in conversation
Top Contributors
User Kudos Count
1
