Reply
Using a second wireless router to extend range?
I have two Netgear wireless routers (WGR614 v7 and WGR613VAL) and would like to know if it is possible to use one of the routers to connect to the Internet and use the other router closer to my devices and have the two work together wirelessly.
I'm trying to use the remote router to help my PC and XBox 360 get better conenctions to the Internet (the PC is using a Netgear WG111v2 USB adapter and constantly drops the connection to the router). I would like to wire the PC to the remote router directly and use the router to connect to the router that hooks up to the Internet.
Is this possible?
Luminary
Re: Using a second wireless router to extend range?
this model can not wireless repeat. only setup as an access point such as below
http://kb.netgear.com/app/answers/detail/a_id/965
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Bummer, I was hoping that with the two routers I could get some better range.
Thanks for the reply.
Luminary
look at WNCE2001 or WN2000RPTT extenders
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Thanks for sharing this useful link.This is very important for me because i got required information from this link.
Hi
I have a netgear WGR614v7, does anyone know if this can be used as the primary router on a network that has a secondary router that is connected wirelessly and Supports WDS wireless network extension
Cheers
Luminary
Will NOT work on v7 for WDS
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
I saw from the web it wouldn't work as a secondary router
But your saying even as a primary router it will not work?
Luminary
No. V7 will NOT support WDS so will NOT work ANY router that supports WDS
Both MUST support WDS for wirelessly connect two or Use an acces posing only per URL already posted
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Ok Smiley Sad
thanks for the quick responseSmiley Happy
Discussion Stats
  • 9 replies
  • 15552 views
  • 0 kudos
  • 4 in conversation
Top Contributors
User Kudos Count
1
