Reply
WNCE2001: Admin password possible?
Is it possible to protect the configuration (the Web UI) of the WNCE2001 with an admin password? If not, in which way is the WNCE2001 protected against user access (over WLAN and over Ethernet)?
An additional question: Are german Umlauts possible within WPA/WPA2 keys with the newest firmware?
Bejobe
Luminary
Re: WNCE2001: Admin password possible?
I don't think you can change as you see in GUI
Contact support for feature enhancement at my.netgear.com
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Thank you for your answer.
I do not know what is "in GUI", because I have not yet bought the WBCE2001.
The "access GUI password" is a decisive purchase criterion for me. A (W)LAN device without access password, is this possible? I can not believe that...
I will try it, but why is this official forum not the right place to ask for feature. I do not understand the function of this forum, if it is not to communicate with netgear itself.
What is about my second question: Umlauts in keys?
Best regards
Bejiobe
Luminary
GUI, graphic user interface- device interface, we're you change settings
If you are talking about special character then you need to use basics character sets
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Thanks for your answer.
jmizoguchi wrote:
GUI
I know what a GUI is. My question is, is there an option to set an admin password in the GUI to protect the settings? I do not know what is in the GUI, because I haven't have the WNCE2001 yet.
Really, no support for Umlauts? This is bad, because I have no access to the settings of the WLAN access point, where the WNCE2001 will be connected to.
Two non standard settings in this WNCE2001. Why? Maybe a Firmware Update will help? Or hase the newer WNCE3001 this features?
Bejobe
Luminary
Already said. On this model I don't think you can change the password
Wnce2001 is 2.4 support
Wnce3001 is 5ghz (or dual band)
If you can not access the current AP then maybe an issue
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
What means "don't think ... can change the password"? There is a password?
I understand: the truth is, you do not know it...
Again: Has the Gui password protection, yes or no?
Luminary
Yes and can NOT change it
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Please excuse me, that I ask again.
I understand, the WebUi is password protected and this password can not be changed.
My question: Has every piece of WNCE2001 a different individuell password, or have all WNCE2001 the same password?
Bejobe
Luminary
if you can not change means... its all same..
see the guides and manual yourself at support.netgear.com
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
[QUOTE=jmizoguchi;385991see the guides and manual yourself at support.netgear.com[/QUOTE]Believe me, I have looked in the manuals many times before and after you wrote this... The only (indirect) hint to an admin password, I have found there, is the text "Logout" on the screenshot of the WebUI on page 7 of this manual: ftp://downloads.netgear.com/files/WNCE2001/Documentation/UM/WNCE2001_UM_24Sep10.pdf
Where is the information about an admin password in the manuals (an "official" information about this)?
Bejobe
Bejobe
The web interface is NOT password protected. There is NO password which could be changed. (WNCE 2001 v1 - Firmware v1.0.0.26)
That turns out to be a problem especially because of the recently discovered WPS problem.
As for today, owners of WNCE 2001 devices cannot prevent nearby attackers to try "WPS via PIN". (I don't know yet, if the WNCE is vulnerable for the WPS-via-PIN attack.)
Heiko
The WPS flaw seems not to be this serious for the WNCE. It depends on the implementation of WPS on the access point. I'm sorry for that. Forget what I said before, except that the WebUI is not password protected.
Discussion Stats
  • 12 replies
  • 11934 views
  • 0 kudos
  • 3 in conversation
Top Contributors
User Kudos Count
1
