Reply
Windows 8 WNA 1100 HELP !!!!!!!!
I have win 8 and have been given a WNA1100 by the numbskull who built an £1100 computer for me without a wireless card. (his excuse - I didn't ask for one !!!!! Well, I didn't ASK for a casing around the innards, either. Foozling Idiot))
So I've installed from the cd that came with the product.
THEN discovered that my only result was a frozen screen and the Blue Screen of Death.
I've downloaded and extracted the ZIP File from Netgear support that's supposed to fix it.
I've now got two directories x64 and x86 with three files in each.
AND NO CLUE as to what I'm supposed to do with them (in the nicest POSSIBLE way, of course)
Anyone want to give me a heads-up ?
BEFORE I GO TOTALLY FOOZLING POSTAL !!!!!!!
Computer Professionals, be foozled.
Regards
Merlin
Luminary
Re: Windows 8 WNA 1100 HELP !!!!!!!!
X64- 64bit Operating system
x86- 42bit Operating system
Driver is *.INF file and once hardware is detected, Operating system will automatically see the fit needs and use it...
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Thanx very much for the reply.
Is it at all possible that you could tell me that in a "Tab A goes into Slot B" sort of format.Smiley Surprised
Your reply, I'm afraid, could be well translated as "Drop the goooglyhinch in the afterfeeder and corsetort the affluing doblymunches" as far as I am concerned.Smiley Happy
And little things, like should the extracted files be in any way adjacent to the Program directory (which they for some reason aren't).
And any other things that I need to do but didn't ask about that I don't know I need to know because I don't know them.
Thanx
Ludd
Luminary
It's a driver so you just need to updated the driver from device manager
http://pcsupport.about.com/od/windows-8/a/device-manager-windows-8.htm
Go to wireless device and update the driver
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Could the netgear site be telling it that the driver is current ?
'cos all i'm getting is "this is the latest driver for your device.
Driver is installed correctly"
Luminary
Support.netgear.com
Search products and listed driver is latest
If you have more detail answer contact support via portal at my.netgear.com
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Discussion Stats
  • 5 replies
  • 9427 views
  • 0 kudos
  • 2 in conversation
Top Contributors
User Kudos Count
1
