Reply
how to setup UNIVERSAL WIFI RANGE EXTENDER
hi
I need some of help please
I have the UNIVERSAL WIFI RANGE EXTENDER WN3000RP
I would like to know how to setup UNIVERSAL WIFI RANGE EXTENDER
I have windows 7 and draytek Vigor 2820 Series ADSL Router Firewall
Luminary
Re: how to setup UNIVERSAL WIFI RANGE EXTENDER
you should able to follow the guide that came with it.
use PC with ethernet cable to the extender and setup up.
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Luminary
duplicate
http://forum1.netgear.com/showthread.php?t=69991
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
hi
it doesn't work with ethernet cable to the extender.
the www.mywifiext.net doesn't work
the guide doesn't explain it rightly
Luminary
Reset the unit and try again
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
I tried that
Luminary
Connect a PC to the Extender with an Ethernet Cable
Usually, you connect to the Extender wirelessly, but you can use its LAN port to connect a wired device such as an Ethernet-enabled gaming console, printer, or PC.
Note: Before you connect wired devices or computers, first install and set up your Extender as described in the Universal WiFi Extender WN3000RP Installation Guide that came in the package.
1. Connect your computer to the Extender with an Ethernet cable.
2. Plug the Extender into an electrical outlet.
CAUTION:
Do not use Ethernet cable to connect the Extender to a router. If you do so, the Extender does not work because it is designed to use only a wireless connection to the router.
3. Log in as described in the following section.
If you have trouble connecting:
• If you start your computer, connect the Ethernet cable to the Extender, and launch your browser quickly, the computer might still need a couple of minutes to recognize the Ethernet LAN connection before you can connect.
• Make sure that your Ethernet cable is securely connected to the Extender and the computer, and that the Extender LAN LED is on. If the LED is not lit reconnect the Ethernet cable, and relaunch your Internet browser.
Connecting to http://www.mywifiext.net
If you have trouble connecting, try to locate the source of the problem:
• For help with passwords, see Log In to the Extender on page 8.
• If your browser displays an error page, make sure that you include http:// when you type this URL in the address field of your Internet browser. If you leave it out, you might not be able to connect.
• The Extender LEDs can help you tell if the extender is correctly set up and working as it should.
4
Universal WiFi Range Extender WN3000RP
- The best performance is delivered when both the Link Rate LED  and the PC to Extender Connection LED  are green.
- A workable performance is delivered when the Link Rate LED is amber  and the PC to Extender Connection LED  is green.
If you cannot get a wireless connection working, you can use an Ethernet cable to connect your computer to the Extender. See Connect a PC to the Extender with an Ethernet Cable on page 8.
ftp://downloads.netgear.com/files/WN3000RP/Documentation/UM/WN3000RP_UM_27JUN2011.pdf
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
thank you for your help
I got it working thank you
if I have other of EXTENDER . will it work? I got 2 unit?
Luminary
In general , shouldn't be an issues
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
what is the default password?
Luminary
password ...............
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
I already tried that but it doesn't work
Luminary
suggest to reset the unit
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
I done reset the unit but it is same thing.
I can go in the unit menu without password ok I would like to have password.
other question
how to hook up other unit?
Luminary
some extender do not have able to change it .
if you do not see in the interface then no... this has asked in the thread in the past
if you are trying to hook up addition extender, just find the 1st extender's network SSID and connect but you will loose 50% throughput
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
ok
ok
what about if I connect the second addition extender straight on my router?
Luminary
should be okay but still wifi connects on extender is 50%
so if you were connect 2nd to 1st extender , 50% drop and wifi devices connect to 2nd SSID, it will 25% drop.
so both extender connects primary will on drop by 50%
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
I tried the second addition extender straight on my router. they connected with my laptop but
every time I try to connect either units but only one of unit got internet service
does anybody knows why?
Luminary
each extender has different SSID for wifi devices to connect extender?
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
yes they are different
carlo_EXT
carlo_EXT2
any other suggestions
Luminary
should able to save way with other extender that do work.. s
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
what? I can't understand you
Luminary
Sorry. Phone did some weired thing
If one extender works fine then it should the same on 2nd extender which both extender ate connected to main wireless router
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
I found something very weird
I have have to wait for 10 minutes before to connect itself when I switched between units
why does do that
Luminary
strange but can you still ping your router when you are connected to extender?
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Discussion Stats
  • 35 replies
  • 79388 views
  • 0 kudos
  • 3 in conversation
