× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
A6100 Wifi USB Mini Adaptor - Increase connection speed
cssaus
Just installed an A6100 WIfiFi USB mini adapter and connected by 5Ghz to my WNDR4500 adapter. The connection is running a 150mbps. I thought by connecting to 5Ghz I ought to be able to get a higher connection speed.
Mp laptop with the adapter is physically located about a metre away from the router.
Is there some setting I'm overlooking or is it meant to be that way?
Steve
Model: A6100|AC600 WiFi USB Mini Adapter
Message 1 of 5
Blanca_O
NETGEAR Moderator
Re: A6100 Wifi USB Mini Adaptor - Increase connection speed
Hi @cssaus
Welcome to NETGEAR Community!
What is your subscribed speed? Expected speed?
What is the speedtest result when connected to 2.4GHz?
Blanca
Community Team
Message 2 of 5
cssaus
The connection speed on the 5Ghz channel is 150Mbps. When I connect on the 2.4Ghz channel I see 72.2Mbps. These are the speeds I seen when I go into the Network & Sharing centre & click on the wifi adapter connection.
I was wondering how to achieve the 433Mbps on the 5Ghz channel? I have downloaded and installed the latest drivers. The laptop with the A6100 is within 2 metres of my Netgear WNDR4500 router.
Message 3 of 5
Blanca_O
NETGEAR Moderator
Hi @cssaus
I think you are referring to the link speed. The adapter is dependent with the router. Can you access the router settings page and check the mode?
Blanca
Community Team
Message 4 of 5
Blanca_O
NETGEAR Moderator
Hi cssaus
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
Blanca
Community Team
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 2857 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
