- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
A6100 using alot cpu
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello, i've got this problem for almost 1-2 years now. The solution i have is to stop the genie on startup but i wan't to find a better one time fix. It can go up to critical amount of cpu used by this genie if i dont stop the process. I've tried reinstalling. And i really need this genie so i can't uninstall because my router is to for away. Also t installed it by a CD and then updated it through the program.
Specs:
Windows 7
64 bit
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: A6100 using alot cpu
Hi Kalkonen,
You can still install the adapter without the genie by using the standalone driver. You can try using other drivers that are available in support site.
http://downloadcenter.netgear.com/en/product/A6100#searchResults
- Mark as New
- Bookmark
- Subscribe
- Permalink
I uninstalled the genie and installed the latest stand-alone but there is still A6100 process eating cpu.
