× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
A6100
ruds
Follower
A6100
Hey i just got a pc and it doesn’t have a cd slot and i can’t connect to my wifi so how am i meant to download it?
Model: A6100|WiFi USB Mini Adapter
Message 1 of 3
Accepted Solutions
Re: A6100
How did you post this message?
There is a manual, software and other support stuff for the A6100 at the end of this link:
>>>> A6100 | Product | Support <<<<
Use whatever you used to get here to retrieve the software. Put it on as USB drive and away you go.
You may not need any special software or drivers. Plug it into a USB port and Windows may pick native drivers that work.
Message 3 of 3
All Replies
schumaku
Guru
Re: A6100
Chicken or egg problem ...  so you need an alternate approach.
  • Ethernet cable to the router
  • Download on another computer, store on a thumb drive, and move this to the new computer
Message 2 of 3
Re: A6100
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 3195 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
