× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
A6210.EXE High CPU
sheerbot
A6210.EXE High CPU
Although I don't recall any firmware/dll updates, my A6210.EXE App has been recently running at 30-50% of CPU consistently (no breaks less than 20% ever).  Was there a recent software release which made this happen?  My poor CPU is so busy the fan is always on high, and it's really cramping my gaming....  HELP - is there a solution?  Wait for the next release to fix it?
Model: A6210|AC1200 High Gain Antenna WiFi USB Adapter
Message 1 of 2
Accepted Solutions
sheerbot
Re: A6210.EXE High CPU
Hello.  It was a Microsoft issue.  Microsoft patches made it run at 20-50% CPU consumption all the time.  Then, yesterday, the latest patch reduced it to 0-2% occasionally.  Thanks if you looked at this....
Message 2 of 2
All Replies
sheerbot
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 5953 views
  • 0 kudos
  • 1 in conversation
Announcements
Orbi WiFi 7
