× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
A6210 Software installation
aitchie
Good Day
1. How much space (Bytes) does the software for this device require to be installed?
2. Must it be installed on the C:\ Drive, or can it be installed on another logical drive on the hard disc?
Thanks in advance.
aitchie
Model: A6210|AC1200 High Gain Antenna WiFi USB Adapter
Message 1 of 6
Accepted Solutions
aitchie
Re: A6210 Software installation
For future users, the answers to my queations ( which I established myself through trial & error) are:
1. Netgear requires 16.6 MB (17 469 440 bytes) on the hard drive.
2. Netgear does not give the option to be installed on any but the C:\ Drive.  It can be installed on another logical drive by moving all the files to that drive, then editing the registry - NOT for the faint-hearted.
Aitchie.
Message 6 of 6
All Replies
VE6CGX
Master
Answer 1: If it run out of space, it'll tell.
Answer 2: Any where you want.
Just don't plug it in until asked by the install. wizard.
Good luck.
Message 2 of 6
aitchie
Thanks VE6CGX.  I don't have a lot of space left on my C:\ Drive, that's why I asked how many bytes the installation uses.
Aitchie.
Message 3 of 6
JamesGL
Master
Hi aitchie,
I think it is the same MB as the driver. 40-50Mbps will do.
Message 4 of 6
JamesGL
Master
Hi aitchie,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
Message 5 of 6
aitchie
Aitchie.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 6274 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
