Reply
A6210 not working
TrashPuppet
A6210 not working
Hope this is the right forum and sorry for any spelling mistakes, I'm using my phone which has a broke ass screen.
My wifi adaptor just completely stopped working. I've previously had issues with it, but reinstalling the driver seemed fixed it until now. It was working fine until I restarted my computer (after installing a windows 7 update). I logged back in and no networks were showing up, as if the adapter wasn't plugged in.
I uninstalled the windows updates. I reinstalled the adapter. I've redownloaded the driver via my phone. I've uninstalled tge device through device manager and reinstalled. I can't even get the genie application to open. It'll show up in task manager, but not actually on the screen.
Any help much appreciated
Model: A6210|AC1200 High Gain WiFi USB Adapter
Message 1 of 6
Accepted Solutions
Tom444
Apprentice
Re: A6210 not working
1. Windows 7 is dead Upgrade to Windows 10 for free.
2. Does it work on another computer?
3. Try an older version of the driver for the A6210
Message 2 of 6
All Replies
Tom444
Apprentice
Message 2 of 6
TrashPuppet
Yeah I know, I was gonna upgrade this weekend, but can't now.
I don't have any other computers to try it on.
I downloaded the last three updates, but none seem to work.
Every time I reinstall it, it says device not found or the program won't start. I've tried restoring my computer, but I only had a restore point from after the problem started.
Any time i plug in the adapter and my computer tries to automatically install the driver software it doesn't recognise the device/driver not found.
Message 3 of 6
TrashPuppet
Holy shyeet! I just went one more update back for the heck of it and it finally worked (??). Thanks for replying, i probably wouldn't have bothered if you hadn't suggested it.
Message 4 of 6
nauticalMike
I'm on the Windows 10 1909 version, which driver version are you using?
Message 5 of 6
TrashPuppet
I'd have to check later, but I just downloaded the last three drivers and tried them till one worked.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 5944 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
