- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
A6210 to build a NAS interface
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi, I want to transform an external HDD (USB 3.0 connectivity) into a NAS.
Also, I am the owner of a NETGEAR A6210 WiFi USB Adapter : is it possible to connect the latter to the HDD ?
How to proceed ? How to install required SW ?
Thanks in advance for any hint/help, Regards.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
No.
@Treblig91 wrote:Hi, I want to transform an external HDD (USB 3.0 connectivity) into a NAS.
To most people, the term NAS refers to something that uses an ethernet connection. It does not refer to USB devices. I mention this to save you time on futile web searches.
Some routers and modem/routers have a USB socket that you can use to share a USB device on your local network. In Netgea's case the technology is known as Readyshare. But be careful to check that your USB devices are compatible with this technology.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
No.
