- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
A7000 Can't Connect WiFi
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello all,
I am currently having trouble connecting to a new router I installed. I had the stock Fios Gateway Router that came with my Fios internet and was successfully using the A7000 WiFi adapter. Today I upgraded my router (still a Verizion router just newer) and my A7000 will not connect to the WiFi. I have tried uninstalling the drivers, updating the drivers with no luck. I was able to connect my older A6100 adapter and that immediately works. With that being said it sounds like the issue is narrowed down to the A7000, does anyone have any suggestions on a fix?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: A7000 Can't Connect WiFi
Also would like to add that I'm using Windows 10, and with the A7000 I am able to connect to my phones hotspot, it is specifically my routers WiFi it cannot connect to.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Stomlin11 wrote:
...with the A7000 I am able to connect to my phones hotspot, it is specifically my routers WiFi it cannot connect to.
Kind of suggests that it is the router's wifi that is the issue.
Not knowing what that is, it is anybody's guess.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
What does Windows network troubleshooter say?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
An off the wall one, maybe you need to tell Windows that you are on a "private network".
- Network and Internet settings
- Network Status
- Change Connection Properties
- Network Profile
- Private
I am told that I am talking rubbish when I suggest that, but it has worked for some of us. Nothing lost if I am wrong.
