× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
A7000 Driver memory leak
Running Windows 7, finally discovered the source of the memory leak I've been struggling with. It's the A7000.
Attached picture shows that the driver has leaked half a gig of memory in less than 12 hours. (poomon.exe)
Any hopes of getting a fix for this in any reasonable time frame, or should I just buy an Asus adapter instead?
Model: A7000|NIGHTHAWK AC1900 WIFI USB Adapter
Message 1 of 4
Re: A7000 Driver memory leak
Wonderful spelling error, and too late to edit: the application this capture is from is poolmon.exe, not poomon.exe.
Message 2 of 4
At 18 hours, with actual usage (not just sitting overnight) the outstanding allocations has nearly tripled.
Message 3 of 4
mondenath
Prodigy
which version u have installed . try roll back to 11 version. dont install 15 it had some issues
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2621 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
