Reply
A7000 Extreme drop of internet quality
GuvGuvington
I have a A7000 plug in USB Wifi Antenna and it managed to give me a 200+ mb/s connection (while my phone only managed to get around 1 mb/s) for the last couple weeks since I got that thing.
Yesterday noon the connection suddenly dropped from 200+ mb/s to just 1.25 mb/s for no apparent reason.
I have restarted my PC, reinstalled the program, disconnected and reconnected, plugged my antenna in another USB port, plugged my antenna in without that extension cable and yet, it never gets better. I have also noticed that right after connection to my signal, it sometimes immedially disconnects again, just to reconnect a few seconds later.
Also I can download a new update for my programm, but when I try to do so, the download always fails at 22% and tells me I have no internet connection, despite me very much having an internet connection, or else I couldn't write this.
Please if you have any idea how to fix this antenna to give me internet quality its supposed to do, help me out.
I really dont want to have to refund it.
Model: A7000|Nighthawk AC1900 WiFi USB Adapter - USB 3.0
Message 1 of 5
Guru
Re: A7000 Extreme drop of internet quality
The question is, if this is happening on your phone as well, if its actually the adapter that is the issue and not the router.
What router do you have?
Current setup: CAX80->Trendnet TEG-S380->GS716T-> RBK752->pi-hole
1.4gig download/50mbps upload
We’re members of the public helping out on our own time.
Message 2 of 5
GuvGuvington
I dont know which router I have since its not in my appartment
Message 3 of 5
Guru
Again, if your phone is doing it to, I'd be checking with whoever controls the router.
Message 4 of 5
You won't get far without knowing what is going on at the source of the wifi.
Only then can you begin to sort out if it is the adapter that causes the problem or the devices that delivers the wifi.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 364 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
