Reply
A7000/Nighthawk AC1900 reception speed 54Mbps only
journey001
Follower
Hello
I have just installed the adapter on usb3.0 ports and connected to my wifi  router (802.11AC, wpa2-personal)
I used the last  driver v1.0.0.15 from netgear site.
But when I run cmd -> netsh wlan show interfaces i receive
transmission speed 1300Mbps
the reception speed should be 1300Mbps?
Is there any advanced setting from device manager to tweak?
thanks
System: Windows 10 build 19041
Driver: v1.0.0.15
Model: A7000|NIGHTHAWK AC1900 WIFI USB Adapter
Model: A7000|Nighthawk AC1900 WiFi USB Adapter - USB 3.0
Message 1 of 2
Blanca_O
NETGEAR Moderator
Re: A7000/Nighthawk AC1900 reception speed 54Mbps only
Hi journey001,
Welcome to NETGEAR Community!
If you are still experiencing issue using the WiFi adapter, kindly install lower driver version. Here's the reference link:
https://kb.netgear.com/000045297/A7000-Software-Version-1-0-0-11
Blanca
Community Team
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 725 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
