- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
AC1600 not connecting to 5ghz network
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am running windows 10 and am having trouble with my wireless wifi adapter not connecting to my 5ghz network. connects to the 2.4ghz just fine.
any else have this problem or know a fix?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: AC1600 not connecting to 5ghz network
"Not connecting" doesn't give us much to go on.
Does it see 5 GHz?
What happens when you try to connect?
Do other things connect OK to 5 GHz?
What does the wifi come from?
What is the adapter plugged into?
Apologies for piling on the questions.
You can help people to help you by providing the information suggested in this forum's header:
Subject (Include model number and brief summary)
Model (Recommended - Helps the community give the best answers)
Body (Include additional detail including model version, firmware, OS and environment where relevant.)
- Mark as New
- Bookmark
- Subscribe
- Permalink
I welcome the questions. would love to get it fixed.
It does see the 5ghz
after typing in password it connects for ~10-20 and then says cannot connect to network
all my other devices connect fine so it is probably the adapter
Wifi comes from in house router
would it be a driver problem?
- Mark as New
- Bookmark
- Subscribe
- Permalink
@T_Elderkin
Alternatively, it could be the device that the adapter is connecting to the wifi.
If it really does connect, and then after 20 seconds it throws an error, I would check the network's properties. If this is a Windows thing, then the Network troubleshooter might help.
The adapter may be connecting to the wifi, but the PC (?) is not connecting to the network.
