× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
AC600 won't connect to 5GHz
devildog4
Follower
AC600 dual band adapter wont connect to 5GHz. Always connects @2.4 GHz.
Even when chosing 5GHz it will connect to the slower speed. Passwords are the same except for a number at the end. Could that be the issue?
How do I change the passsword(s), that should solve the issue?
Thx...
Model: A6100|WiFi USB Mini Adapter
Message 1 of 2
Guru
Re: AC600 won't connect to 5GHz
what router are you connecting to?
does it use a single ssid setup or are the ssid's for the 2.4ghz and 5ghz different?
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1535 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
